Badge removal - how to clean the outline of the badge ??
Old Aug 13, 2007
4drcivic01's Avatar
4drcivic01 is an unknown quantity at this point
I want to remove the rear civic/lx badges on my car. I started off with the lx to see how it comes out, since its smaller. It came off really smoothly, but there still is a distinct outline of where the badge was. I mean you can't see it unless you are foot away from the badge, and look at the right angle. What can i remove that with? HELP PLEASE!
Old Aug 13, 2007
jteasley's Avatar
jteasley will become famous soon enough
Re: Badge removal - how to clean the outline of the badge ??
go to your local auto store or even walmart and get some goo gone. stuff works wonders
Old Aug 13, 2007
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
thats to remove the glue if there is any left, other than that you will need to buff or wax it out. Gotta remember that part of your car hasn't seen daylight since that badge was put on so its color will be brighter than the rest of your paint.
Old Aug 13, 2007
4drcivic01's Avatar
well i got the car painted a month ago, and i told them not to stick em on, but they did! so yeah i kinda got it off, will try goo gone..still working on the lx, took of the x and it looks pretty much perfect, now its time for the L...it was broken so yeah...
thanks for the replys tho...
will goo gone damage my paint at all?
Old Aug 13, 2007
PitchBlack's Avatar
nothing will damage your paint as long as you don't leave it on, use it for its purpose then get it off. Most soaps will do the trick, most anything with an emulsifier in it.
Old Aug 13, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
See i have the same problem... after someone yanked off my badge and i used goo gone and some stuff to get rid of the foam, there was that film that still reads civic..
I still don't know how to get it off.... waxing doesn't work, and more goo gone doesn't work either.
Old Aug 13, 2007
civicfan1203's Avatar
Look at me im a supporting member
civicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nice
i just used my bug and tar remover on mine it came out fine
Old Aug 13, 2007
4drcivic01's Avatar
mine looks pretty good but i f**ked up big time..when i just had little strip of adhesive i tried heating it up more with the heat gun, maybe 3 seconds and now i got a pebble size dent in my car =/. I really didnt think it could happen that fast..im so mad..ill take a picture right now how it came out tho. and post it in few mins
Old Aug 13, 2007
LT2004ever's Avatar
if u have a dent, but a can of compressed air, turn it upside down spray it on the dent, so it looks like its frown over then heat it up with the hair dryer, and the dent should pop out.
But back on topic, i think imma try some alcohol/acetone on the area.... just not gonna apply it in the sun or for too long.
Old Aug 13, 2007
4drcivic01's Avatar
the dent looks even worse then i thought! i thought it would be hard to get it in the pics but damn it doesnt look too pretty. Anyhow to remove the adhesvie I used alcohol pads, windex, and then cleaner wax and it looks 98% spotless. I will get the civic one off tomorrow.
I would like if you gave me more specific info on the compressed air, and dent poping out! thanks
Old Aug 13, 2007
DsevenEm2's Avatar
This is Myspace
what a mess.
Old Aug 13, 2007
LT2004ever's Avatar
http://www.autoblog.com/2007/05/29/v...ompressed-air/
http://lifehacker.com/software/macgy...yer-254575.php
same vid
edit: ok cool i will try the alcohol pads, windex, and then wax also.
Old Aug 13, 2007
4drcivic01's Avatar
in that video the dent is kinda big. Does anyone else know what else i could use to remove that dent? is there like a kit, that will like suck the dent and so it pops? lol, i've seen it somewhere...ill try to look online for it.
Old Aug 13, 2007
4drcivic01's Avatar
something like this? http://cgi.ebay.com/ebaymotors/POPS-...ayphotohosting
Old Aug 13, 2007
LT2004ever's Avatar
^^ yup yup those work as well. they are awesome
Old Aug 13, 2007
azn_knight4874's Avatar
azn_knight4874 is an unknown quantity at this point
i did this a few weeks ago on my civic and it worked great.
once the badge is off, and you peel off as much glue stuff and you can then...
get an old cotton t-shirt, wet half of it and leave other half dry. take turns rubbing the left over glue, with the wet part of shirt, then the dry part of shirt and it should come off pretty easliy.
*Note: i did mine on a day that was like 100 degrees. weather also plays a role as well.
mine came out great, didn't need or want to use any chemicals on my paint job. now it looks clean, no outlines or anything.
good luck!!
Old Aug 13, 2007
meguiars scratchX works too cause it very gently polishes the clear coat so it would take off anything that was there. just wax when youre done.
Old Aug 13, 2007
Nokturnl's Avatar
Crawlin Similar To An Ant Low To Da Earth
Nokturnl has a spectacular aura aboutNokturnl has a spectacular aura aboutNokturnl has a spectacular aura about
I used a brillo pad and some sand....just barely hazed the paint but looks nice from my house
Old Aug 13, 2007
mine also turned out great
Old Aug 14, 2007
4drcivic01's Avatar
yeah thanks for all the replys, for me the soap/sponge, windex/cloth and alcohol pads worked really well. Took some patience and didnt come off right away, but after couple of rounds it came out like the badge was never there. I used a cleaner wax for a nice shine at the end...
but i need to fix then dent real bad. please help!! ill probably make another thread about it, unless someone can help me here..lol (if you don't know, my heat gun (when i was heating up the adhesive) caused a pebble size dent on my bumper that i need to get rid off it. Look in the picture above to see...thanks in advance
Old Aug 14, 2007
LT2004ever's Avatar
are u serious....
Old Aug 14, 2007
4drcivic01's Avatar
to take the civic part, i went to a local auto shop and the guy told me gasoline works really good and will not damage the paint at all...so i used gasoline to clean up the resedue, it didnt come off easily but did come off way easier then the previous methods i tried...=]
now my ride is badgeless except the honda trunk badge...hmm what if i took that off and put the civic there? lol
Old Aug 14, 2007
LT2004ever's Avatar
there are 2 holes behind that badge
Old Aug 15, 2007
4drcivic01's Avatar
hmm really? there might be no holes on mine, because it is glued with the adhesive (remember i got my car painted so maybe they filled the holes up)
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
wasa67
Jun 27, 2015 01:47 AM
Optimus34
May 25, 2015 11:52 PM
Grey
17
Feb 21, 2004 06:21 PM
slikor
Nov 1, 2001 04:13 PM
