Engine/tranny shakes at low RPM takeoff.
Old Jul 22, 2007
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
I've had this problem since I bought the car, a 97 DX 5-speed in stock configuration, 105k miles with new tranny fluid in it. The problem is that if I don't rev high enough and I engage the clutch, the whole engine/tranny will shake really bad. This shake will even happen when driving really slow where low-rpm is a must.
However, if I leave the car sitting for like a day without it being driven --the longer the better-- the problem disappeares. My friend told me that he was listening to Click & Clack, and a man with a 5-speed accord phoned in and said that his engine shakes if he doesn't rev hard enough. The response was that either a spring is worn in the clutch or tranny (can't remember which) or there is dirt on the clutch plate. Something like that. But what spring would that be? Sounds like my problem since if I let the car sit, the tranny feels as it should, indicating that a spring has regained tension.
What do you guys think?
Old Jul 23, 2007
Re: Engine/tranny shakes at low RPM takeoff.
Eh, there's really nothing wrong with it. I'm just sinking the clutch in too far and too quickly--gotta baby it in.
Old Jul 27, 2007
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
sometimes when there is shaking or chattering it could be a sign of oily greased clutch
Old Jul 27, 2007
spoonEM's Avatar
omgwtfbbq mod.
it has nothing to do with your clutch. You have a broken or torn motor mount. Get underneath the car and check all of your motor mounts. I guarantee one of them is torn..most likely the front one. I know on our cars, the motor mounts are notorious for tearing. It sure wouldnt hurt to change the clutch with that many miles, but that isnt whats causing your shake. Check the mounts.
Old Jul 27, 2007
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
^^^ agreed on the mounts
Old Jul 27, 2007
to test the mounts either put the car in first gear and press the break down at the same time and have someone check how much the motor moves....OR the easiest one to check ....get a pry bar BIG ONE! or something big and stiff (hehe) O_O!! and put it against the subframe and move the engine see how much it moves hope that helps
mrohitredd
May 30, 2015 06:51 PM
mrohitredd
18
May 14, 2015 07:35 PM
dooner24
Apr 14, 2015 07:51 PM
Aznnp77
Dec 13, 2001 04:03 PM
