Brake light out, yet bulb is fine
Old Jul 21, 2007
masterguns's Avatar
masterguns is an unknown quantity at this point
Can anyone help me? My 02 coupe's brake light is out on the driver's side. The bulb is shines when I turn my headlights on, but does not get brighter when I hit the brake. I've tried replacing the bulb, but it doesn't work. I don't know what could be the problem? Does anyone have any ideas? Thanks.
Old Jul 21, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Brake light out, yet bulb is fine
Check the fuses.
Old Jul 21, 2007
masterguns's Avatar
All the fuses are intact. I don't know what the problem could be.
Old Jul 21, 2007
DeX's Avatar
DeX
Canadian, Eh!
Put a voltimeter on the wires to see if you're getting power. Are they gone on both sides? Can you switch the bulb from the other side that you know works?
Old Jul 22, 2007
CraigW's Avatar
Inspect the socket, may be corroded or one of the pins could be damaged.
Remove and install the connector going into the socket. (re-seat)
Get a meter or test light to check if voltage present.
Old Aug 2, 2007
ashokudu's Avatar
ashokudu is an unknown quantity at this point
Same thing happened to my lincoln, the bulb looked fine, but guess what it wasn't fine.....so dont dig too deep, check the basics first just like masterguns has said
Old Aug 6, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
brake switch?
Poopies
Apr 20, 2017 11:36 PM
Ma213802
May 18, 2015 07:01 AM
bsmiley
Apr 27, 2015 01:27 PM
supercivic01
South
Nov 30, 2001 11:27 AM
sonsonzai
Nov 4, 2001 12:52 PM
