lighting problem please help.
i have a 01 ex coupe the other day my wife was driving the car and it made a clicking noise. and the gauge light shut off all you see is what gear it is in. it also made my back driving lights shut off so at night noone can see me unless i apply my brakes. i check all my fuses they all seem to be fine. can anyone help me with this problem. or what may be the problem? thank you.
Re: lighting problem please help.
Did you check the underhood fuses? Here's a nice thread to check out
https://www.civicforums.com/forums/2...ml#post4101843
funny thing i just got done reading that post, its sounds like the exact same thing. cause its the same fuse thats blown and i just got a system put in a few weeks ago i have no clue which wires behind my headunit need to be capped
im a newb with electric things. the day before my fuse blew i had my head unit out trying to reconect the remote wire. can you lead me in the direction on which wires need to be capped please?
im a newb with electric things. the day before my fuse blew i had my head unit out trying to reconect the remote wire. can you lead me in the direction on which wires need to be capped please? Joined: Feb 2006
I know jack **** about wiring bro...But I posted that up so you could see what fuse to check under the hood, I remembered putting up a picture as to it's location in that thread. I'd check that first, seeing as it's easier then tearing apart your whole insall looking for bad caps
ya its that fuse for sure i changed it earlier, and i went back out thier and its blown again. just sucks cause i have to leave in 20 minutes and i dont have time searching for the wire right now. and i have to drive in the dark. mabye ill just drive with my hazards on till tommorow. hopefully thats all it is. if not ill post more. thank you.
What brand headunit ??
Most illumination leads are Orange or Orange/White stripe. (not all)
Do not replace the fuse again until they are taken loose.
thana
Jun 15, 2020 07:05 PM
steveneddy
May 19, 2015 02:39 PM
Linda0818
Apr 23, 2015 11:30 AM
dooner24
Apr 14, 2015 07:51 PM
