02 Civic EX Transaxle Fluid Change
How do I change all the fluid out of my 02 EX transaxle? From reading my Haynes manual, it appears that only a portion of the fluid drains out, with another 4 quarts left in the torque converter. What I found out so far is to change the fluid 3-5 times in short order and you will have mostly new fluid
My local mechanic put Dexron III / Mercon fluid in my replacement transmission. The mechanic added LUBEGARD® Highly Friction Modified-ATF Supplement that converts DEXRON II,III/MERCON ATF into a highly friction modified fluid. I am uncomfortable with this product, as replacing the transmission again is expensive. Do I need to worry.
Do I need to go somewhere to have it flushed? I have an air-compressor in my shop, is there some way I can force most the fluid out in one shot?
Any thoughts and or ideas are greatly appreciated.
Re: 02 Civic EX Transaxle Fluid Change
you could always go to your honda dealer where they have a power flushing machine used specifically for taking out all the old fluid from your auto tranny.
however, there are some people who suggest to do only a simple drain and refill. the reason is because there is a chance that when all the old fluid is forced out, the crap from the old fluid, shavings, etc. will get jammed in your torque converter damaging it.
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
