Help w/ electric fan
My electric fan isnt coming on. Is that just the relay? I think it may be one of two things but im still learning to work on Civics. The fan does work, I "hot wired it" and it comes on. This is on a 93 Civic EX. Any pics, tips, or where I can snag a cheap relay would be appreciated.... ...
thanks in advance..
thanks in advance..
Re: Help w/ electric fan
all relays are cheap. go to autozone or something. it could be a few other things besides a relay. does the condensor fan come on when you turn the a/c on?
Yeah im pretty sure the condensor fan comes on.. the ac works pretty well. The relay is hardwired into the harness, I thought it would just pop off and replace... should I just cut it off and wire in a new one? I think its a 4 wire/ 4 prong or something.
http://www.partsamerica.com/ProductD...pe=600&PTSet=A
I think its this
I think its this
I had the same problem on a 98 Civic EX. The fuse for the cooling fan is in the fuse block next to the battery.
My fuse was blown. It is a mini 20 amp fuse at the rear right of the fuse box (Need needle nose pliers to remove it).
I replaced the fuse and the fan is now working.
The relay is in the same fuse block.
mjdiaz89
Jun 21, 2016 09:26 PM
cizsak
Jul 21, 2015 03:39 PM
Kyles24
Jul 12, 2015 09:15 PM
