Help w/ electric fan
Old Jun 11, 2007
feedphillipnow's Avatar
feedphillipnow is an unknown quantity at this point
My electric fan isnt coming on. Is that just the relay? I think it may be one of two things but im still learning to work on Civics. The fan does work, I "hot wired it" and it comes on. This is on a 93 Civic EX. Any pics, tips, or where I can snag a cheap relay would be appreciated.... ...
thanks in advance..
Old Jun 11, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
Re: Help w/ electric fan
all relays are cheap. go to autozone or something. it could be a few other things besides a relay. does the condensor fan come on when you turn the a/c on?
Old Jun 14, 2007
Yeah im pretty sure the condensor fan comes on.. the ac works pretty well. The relay is hardwired into the harness, I thought it would just pop off and replace... should I just cut it off and wire in a new one? I think its a 4 wire/ 4 prong or something.
http://www.partsamerica.com/ProductD...pe=600&PTSet=A
I think its this
Old Jun 14, 2007
what do you mean hardwired? did they solder the wires to the relay without using any type or wire terminals? if its done wrong, redo it the right way.
Old Jun 18, 2007
bluedot's Avatar
bluedot is an unknown quantity at this point
There are several reasons the fan will stop turning on. Not enough coolant in the system, relay is blown, fan switch is bad, t-stat is stuck shut, blown head gasket.
Old Jun 19, 2007
dapasda's Avatar
dapasda is an unknown quantity at this point
I had the same problem on a 98 Civic EX. The fuse for the cooling fan is in the fuse block next to the battery.
My fuse was blown. It is a mini 20 amp fuse at the rear right of the fuse box (Need needle nose pliers to remove it).
I replaced the fuse and the fan is now working.
The relay is in the same fuse block.
mjdiaz89
Jun 21, 2016 09:26 PM
cizsak
Jul 21, 2015 03:39 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
