Synthetic Tranny Fluid? 5 speed...
Old May 19, 2007
feedphillipnow's Avatar
feedphillipnow is an unknown quantity at this point
Ive heard mixed opinions about synthetic tranny fluid. In my Chevy 4 speed I use MT-90 redline. I read on some Civic site a dude was saying that in Civics it can eat up the synchros? Its on a 93' Civic, 5 speed EX.. miles are unsure, want to put in the right thing... any reccomends? Is there a tranny oil filter also I should be changing? Is it easy to get to? Any pics of install would be sweet... Im just getting used to working on imports so any tips... as said before... would be cool
Thanks ...
Old May 19, 2007
CivicHatch9one's Avatar
7th gen old timer.
CivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond repute
Re: Synthetic Tranny Fluid? 5 speed...
i use redline mt90 in my altima. and got great results.
Old May 23, 2007
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
I've been using synthetic MT fluid since 10k and my '03 civic now has 128k.. No problems here. I run Red Line MTL and love it, night and day difference when compared to Honda fluid in my opinion. I'm not sure if MTL is the right weight for a 93 civic, so I'd look into that.
Old May 23, 2007
What are a few synthetics or blends that are safe for a 93?
Old May 23, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Back then it was just oil in the tranny. So synthetic oil should probably help more than gear fluid.
Old May 23, 2007
sl33pyriceboi's Avatar
use GM synchromesh friction modified
its wonders...alot of the s2k guys use it....search it on this forum n you'll see wt i mean.
Old May 24, 2007
Any special weight?
MAn... oil gets confusing...
Old May 25, 2007
The guy at Kragen Auto Parts said any 10/30 or 10/40 MOTOR oil for a 93 manual tranny civic. Is that cool?
Old May 25, 2007
ragingSPAM's Avatar
I just burnt my tongue
most older d series and b series manual transmissions take 5w-30 or 10w-30 regular oil...you dont need anything special
the 7th gen 5 speed trans take special honda synthetic transmission fluid...if you dont use it you can risk popping out of gear and you can eat up syncros...
other manuals can take gear oil like 75w-90 or 80w-90 regular and synthetic...amsoil also makes a special transmission oil availible too like a lot of other companies...automatics usually take dexron with addative like mercon 5 or jvt for hondas...mobil has a fully synthetic atf availible for almost any vehicle out there...its good stuff
Old May 25, 2007
Nokturnl's Avatar
Crawlin Similar To An Ant Low To Da Earth
Nokturnl has a spectacular aura aboutNokturnl has a spectacular aura aboutNokturnl has a spectacular aura about
I am using Royal Purple Racing 21 oil in mine. that is what the royal purple tech told me to use. Working fine for 10K as of nowJust my$.02.
Old May 27, 2007
Cool... I'll just pick up some 10/30 synthetic then. Ive never changed the tranny fluid on a Civic, is there a filter also I should be changing? Thanks.. I have a long piece of 1/2 hose and a homemade funnel, I heard that would be quite useful.. its what I use on my Chevy to fill and drain the trans..
sf3r8z
Apr 19, 2016 01:53 PM
mistahlorax13
21
Nov 18, 2015 12:47 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
speedlever
Sep 24, 2015 07:18 PM
dantheman42
Sep 4, 2015 01:10 PM
