new engine for my civic
Hi everyone, I'm new to this forum and new to this whole civic/import world. I dont know a whole lot as of yet, so I'm trying to learn as much as possible.
OK, I have a 1996 Civic Hatchback, it looks the part (body kit, wheels/tires etc etc) BUT, only has a stock 1.6L engine!...I've narrowed it down to 2 engines, but cant decide what one to go with. I'm hopping someone on here can help me in my decision.
it's either gonna be a 1.6L DOHC VTECH (there are a few different ones out there, i dont know the difference between them) OR the H23A 2.2L with 220hp, I'm told thats the engine out of a prelude i think.
I've been told that i should go with the 1.6 because its easier to get parts for, I dont know how true this is...I just want as much power to the wheels as possible
Thanks in advance for any replies
I just burnt my tongue
Re: new engine for my civic
nice job on picking the hatch up but get rid of the kit and altezza tails and get yourself some oem bumpers and etc...anyways you have many engine choices but h23a or the h22's from the preludes are hard swaps...you're better off with a b16a from a 99-00 civic si or b18c1 from a gsr...easier drop in swap...i have a 2000 hatchback that im workin on and im gonna keep it 1.6l sohc for the meanwhile with a turbo kit...oh and btw its vtec not vtech
and last but not least:
welcome to the forums
all show and no go
Keep in mind turbo takes some work and its not just one of thoes things you slap on and take it for a spin to test the gains. But as far as the tails, I they arent horrible, I rather see you tint them before you loose them- they might look pretty good.
As for the kit, I guess its a little much, but I've seen so many people put so much wrong crap on that hatch that it just doesnt bother me much anymore and to be honest, I think its kind of acceptable, on that car. The rear spoiler does look a little large though. But its a nice car to start with, I've been wanting to pick up one of thoes cars to mod on the side.
Welcome.
Welcome.
any b series motor would be a vast improvement. but i would stick with a b series for sure. h series are heavy motors and it will make the car push in turns a lot more than it already does.
hhmmm...Im still kinda stumped though. The 1.6L I've looked at are WAY more expensive than the H22A prelude....BUT, like you guys said...it is a heavier engine AND its a much more difficult swap.
Another question...or comment maybe....anyways, it still puzzles me, lol. Im read about these guys who combine different blocks with different top ends. For example, a B16a head and intake manifold with a B20 block...what are the benifits or are there any from making an engine like this??
Thanks again guys for all the replies. VERY much apriciated!
Just get a b18c1, a integra gsr engine. It'll give you 170hp. It depends on how much money you have. Bang for you buck, a b18 or b16 motor is more worth while. Keep it stock until you learn more about cars then turbo it later. B series engines respond really well to turbo.
The B series are like the small block chevy engines of the import world. There's a lot of aftermarket support and there very reliable engines.
Oh yeah, the b20 block is really weak compared to a b18 or b16 block, so you would have to build it up. Its not really worth it.
http://www.honda-tech.com/zerothread?id=684550
a WHOPPING 42 pounds difference. I'm fairly certain he could find a few things that weigh 42 pounds to remove....
I wouldn't be talking about uneducated posts....
a lot of people have already said it, but handling characteristics are most DEFINITELY different with an h22 in a hatch or even in a coupe. and I don't know if this applies for the hatches, but I know in an EJ you had to get different headlights for the swap to fit right. it's much bigger in general than a B-series.
i'd go b18c1 or the b16 from the si. they'd be the easiest swaps for sure. you'd have a good motor right out of the box, and it'll be quick. later on, you could still do an LS/VTEC or turbo it if you wanted. you talked about a b20 bottom end and v-tec head, that's a crv/vtec, not as desirable as a b18 LS bottom and v-tec head.
whatever route you go, hopefully it all works out!
if you really want to make good usable power with a b20/vtec use the ls cams as well as the ls i/m and a gsr or type r ex. mani, you can make a lot of power using stock parts......
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
