Help Locating my intake manifold
I am new to this Civic forum and i am no car guru!!!!! however, i have heard how wonderful this sea foam cleaner works and purchased some the other day. I know how to use it and all that i just need to know where my intake manifold is located???? Like i said i am no car whiz and am fairly dumb when it comes to what under my hood! i would appreciate a pic diagram or something if anyone can help.......???? I have a 2002 ex. coupe. ...Thanks is advance
Re: Help Locating my intake manifold
You're intake mani is underneath your throttle body if you know where that is. Picture where your header is...the intake mani is on the otherside of the block. Let me know if you're still confused.
yea im still confused! ahaha.....like i said im no whiz...i dont know any terminology. Pictures do wonders.........if u know what to hook up to the can of sea foam that would be awesome....i need a pic or i cant unerstand! lol sorry and thank u as well
follow your intake box...its black and starts over by the battery...follow the tubing back to you throttle body...then right underneath that is ur intake manifold
goodness people.....PICTURES PLEASE>>>>>>this is not helping. I dont know **** about what things are called....at all...no throtties dotties manis fannis.......just show a pic of what is looks like on my car please lol
the shiny blue pipe is my intake. the end that doesnt have the big *** filter on it, is connected to the top of the throttle body, below that is the intake manifold. however, if you don't know what it is, should you be trying to clean it yourself??
i'm not familiar with how that stuff works, but i would assume you'd at least have to take your intake off.
New Mod on the Block
please dont attempt this yourself. you're just asking for trouble everytime you open your hood if u dont even know what the intake of your motor looks like.
if you search seafoam, you'll get plenty of stuff for it.
its the brake line vac.
you needa feed the seafoam through the brake line vac.
This is looking at your intake manifold as if you were sitting in your seat and there was nothing between you and the moter. Your throttle body goes on top of the little spacer (labeled with a #1). The oil filler cap is about 4 inches up from the furthest left port on the EGR plate (labeled with a #7). The IM itself is black plastic and hidden underneath your air filter box. If you are going to proceed and do the Sea Foam yourself, be sure and take it slow and follow the instructions EXACTLY. This isn't just a "hook up the can, start the motor, and 5 minutes later your motor is automagically clean" kind of deal.
OMFG do you even know where to put the gasoline in? i would believe it if you said no.
The IM is right next to where you add the blinker fluid.
i also have vtec fluid for sale... paypal me $6+SH
(they usually for for $10+)
sl33pyriceboi@gmail.com
