How Much HP will N/A B16a make..?
Old Apr 3, 2007
FerioRallyB16a's Avatar
FerioRallyB16a is an unknown quantity at this point
i m looking to go N/A on usdm b16
w/ valves, V springs, retainers,some gsr valves, cam gears and shafts
which combinations(brand) are known to make GOOD HP...?
thank you
Old Apr 3, 2007
Re: How Much HP will N/A B16a make..?
let me get the question more details..
how much punishment can OEM gsr valves n springs take..?
what type of shafts is best(has just enuff power so i don damege internals) for gsr valves/springs..?
thank u
Old Apr 6, 2007
sql_civic's Avatar
Wrong forum for this question. You're not likely to get B16 experts visiting here as the 6th Gen Civic uses D16 engines.
Old Apr 30, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
i just sold my 90 integra (DA) 4dr. with a b16 swap, this is what i did
head & intake manifold port and polish, JE frogger throttle body, type-r cams, every moving part from the head gasket up was changed to type-r, dc header w/ drag heat wrap, full 2 1/4 inch straight pipe header back exhaust, injen cold air intake w/ arospeed mushroom filter, i converted from obd-0 to obd-1 for better tuning, ive always noticed that obd-1 is better than obd-0 or obd-2a/b to tune, vtec controller, ballenced pistons rods and crank, this made it so i could get light weight pullys and balencer because there was no vibration, msd ignition, i put in b20 injectors but i dont know if it made a diff., AEM fuel rail and regulator, type-r water pump, a chipped ECU and a chrome valve cover lol, thats all that comes to mind and i had the 160hp 111tq at the flywheel b16 and i got it to 197hp 134tq of 100% untuned power to the ground and i could rev to 10,000 but i never did, id take it to 9000ish and got scared because i put to much $ in it to blow it up but the kid i sold it to bounces off the rev. limiter all day long and all he had changed was the cam seals...., i got pics via myspace search e-mail mrkevindshore@yahoo.com
this is my repost.... i hope it helps
Skillzzz
Jun 26, 2015 09:46 PM
tiredwolf
Aug 28, 2003 09:58 PM
Player1
Jun 14, 2003 04:31 AM
FoolLove
South Cali
Mar 8, 2003 03:03 AM
AlexLx
Feb 26, 2002 03:44 PM
