PCS XFC Install
PCS XFC Install
Alright, i got my xfc today from dezod and hooked it up. i have the optional pressure sensor and hooked up 1 wideband to it. now my main question is that does 01-03 civic have maf sensor???? for some reason, when i look at ecu pinout, i dont see MAF.
Im wondering cuz i have the PnP for 01-03 civic but its connected to MAF in and out. and also when i start to be online, my MAP shows -29 but car is not started????? oh and sometimes the MAP sensor reads under TPS
so anyone with XFC pls help me
Thanks in advance!!!
Re: PCS XFC Install
Im going on boost with my D17.. Is you motor the same if it is i need help... How do you get after market injectors to work.. What is XFC
Re: PCS XFC Install
I know alot about this unit, i have hooked up a couple. Our cars do not have maf sensors. We have a map sensor. You should hook up the 3bar gm map sensor. Should be a red/wht,yellow/red, and black/wht wires..The yellow/red wire will go to your gray/white wire. If you have any questions call me at 910612-6168..Are you using the base map i made for our cars for the xfc?
Re: PCS XFC Install
thanks
Re: PCS XFC Install
Re: PCS XFC Install
Well it all depends on how much power u want! RSX-S injectors(witch i use) works great but will max out at 200HP of what ive heard. so for stock motor i think that those injectors are fine. as for hooking them up its very simple. its a plug and plug the they are a bit longer so u have to add some sort of extension for your fuel rail. not hard to do.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
