PCS XFC Install
Old Apr 3, 2007
boostedEL's Avatar
boostedEL is an unknown quantity at this point
PCS XFC Install
Alright, i got my xfc today from dezod and hooked it up. i have the optional pressure sensor and hooked up 1 wideband to it. now my main question is that does 01-03 civic have maf sensor???? for some reason, when i look at ecu pinout, i dont see MAF. Im wondering cuz i have the PnP for 01-03 civic but its connected to MAF in and out. and also when i start to be online, my MAP shows -29 but car is not started????? oh and sometimes the MAP sensor reads under TPS so anyone with XFC pls help me
Thanks in advance!!!
Old Apr 3, 2007
Silverstreak04's Avatar
Silverstreak04 is an unknown quantity at this point
Re: PCS XFC Install
Im going on boost with my D17.. Is you motor the same if it is i need help... How do you get after market injectors to work.. What is XFC
Old Apr 3, 2007
WilmncChris's Avatar
WilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of light
Re: PCS XFC Install
I know alot about this unit, i have hooked up a couple. Our cars do not have maf sensors. We have a map sensor. You should hook up the 3bar gm map sensor. Should be a red/wht,yellow/red, and black/wht wires..The yellow/red wire will go to your gray/white wire. If you have any questions call me at 910612-6168..Are you using the base map i made for our cars for the xfc?
Old Apr 3, 2007
boostedEL's Avatar
Re: PCS XFC Install
Ill give you a call tomorow. working at 6am and done at 2pm. ill call u after
thanks
Old Apr 3, 2007
boostedEL's Avatar
Re: PCS XFC Install
Oh and yes im gonna start with your base map.
Old Apr 3, 2007
boostedEL's Avatar
Re: PCS XFC Install
Well it all depends on how much power u want! RSX-S injectors(witch i use) works great but will max out at 200HP of what ive heard. so for stock motor i think that those injectors are fine. as for hooking them up its very simple. its a plug and plug the they are a bit longer so u have to add some sort of extension for your fuel rail. not hard to do.
Old Apr 4, 2007
Re: PCS XFC Install
That is fine call me whenever...
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
