clutch problem
Old Apr 2, 2007
edrulz2003's Avatar
edrulz2003 will become famous soon enough
clutch problem
hey guys my k20 swap is givin me some problems...when i did my k20 swap i already didnt have 2nd gear so i been ridin around without it....4,000 miles later today i noticed a smell maybe a burning clutch and when i popped my hood i seen a lil white smoke... ok i let it sit for a hour while i was at school so i could take it home and on the way home while i stopped a stop sign i engaged the clutch while in 3rd the car shut off ...i though maybe it was me so i did it again while goin from reverse to 1st and it shut off again..now when i engage the clutch it makes a squeal..u guys have any idea what this might be let me know...
Old Apr 2, 2007
TRIZ's Avatar
Re: clutch problem
yikes. I'd stop driving it right away. No1 wants to see this turn into one of thoes threads that starts off with an engine problem, and then ends with a busted motor.
Old Apr 2, 2007
edrulz2003's Avatar
Re: clutch problem
ok but im sure its a tranny problem or maybe a clutch ..can that have that much effect on the motor...i hope not, i think tomorrow im takin to a tranny place to get it looked at and possible re built...so does anyone know what the problem might be?
Old Apr 2, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Re: clutch problem
Sounds like you are correct.
Transmission is cooked, and your syncros are probably done as well because you are skipping gears too often. And probably clutch is worn out.
But it also sounds like a problem I've read on k20a.org where if you do not have the proper grounds on your transmission block, engine etc. your shifts will be messed up.
Old Apr 2, 2007
Nameless's Avatar
TURTLEonK
Re: clutch problem
you might be better off getting a another transmission altogether. Are you running KPRO? If so, go with an 05-06 Tranny.
Old Apr 2, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
Re: clutch problem
the squeal sounds like a throw out bearing. and the reason its dying when you go into gear could be the clutch never disengages when you mash the clutch so youre basically putting it into gear without pushing the clutch and its dying. transmissions are very delicate creatures. i would take it to a very reputable shop before i drove it anywhere else. keep in mind, transmission shops are the highest rip off shops of any other area of a vehicle.
Old Apr 3, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Re: clutch problem
After reading of what's been said, I can tell the following:
Funny smell and squiling noice when clutch pedal pressed down?
As well as you cant move in to a gear - these all symptoms of worn out clutch.
Skiping gears wont make any damage to clutch ot transmission.
If you had issue with tranny prior clutch, then definately check the traany while changing clutch.
I'd also check for worn bushings or cable ajustments in the shiter's assembley after you fix your clutch.
I hope it helps.
Old Apr 5, 2007
SpeedFreak's Avatar
SpeedFreak is an unknown quantity at this point
Re: clutch problem
Haveing a hard time, or not being able to engage a gear would be the tranny. Also since he didnt mention any slippage, I wud assume the clutch is still in ok shape.
Old Apr 8, 2007
Re: clutch problem
Old Apr 8, 2007
Re: clutch problem
Whith running engine you wont be able to engage gears without properly functunung clutch.
Old Apr 8, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Re: clutch problem
Its the throwout bearing. More than likely the clutch was out of adjustment the fork was pressing on the throwout bearing, this makes the throwout bearing constantly work. Ill will eventually seize, stall the car at low speeds and shortly after it will wreak havok on your whole drivetrain if it hasnt already. The smoke you may be seeing is probably the grease in the bearing cooking or the clutch simply making contact with the pressure plate even with the pedal pushed in. Gears not properly engaging and squealing can definetly be other symptoms of this. I saw the aftermath of this happening once. H22 tranny in about 300 million peices, snapped a chromoly flywheel right off the crank and pulled half the bolts out of the block. Thank god it wasnt our car, that thing was sickening to work on, haha.
dinsum
May 28, 2015 09:30 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
CaptainAmerica
Feb 3, 2002 09:36 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
