info on my 93 del sol si
i would like to now what engine they came with stock, my serial number says its an si but its not a v-tec now i was talking to some americains on honda tech.com but they seem to be confused on if my car comes with a dohc zc 1.6L or a b16 , and i want to drop a v-tec into it with out paying aolt and changeing my tranns and axciles if possible. What car could i find the motor ex 95 civic si v-tec
Re: info on my 93 del sol si
I'm pretty sure your car has a 1.6L d16z6. There were also del sols with a b16a3. I highly doubt it has a ZC though. I think those were only in CRXs and older JDM civic si's and JDM tegs.
It shouldnt be hard to tell what you've got. Just looking at it should determine if it's DOHC or SOHC, and your engine code should be stamped on the front of your block.
hope this helps:
http://www.superhonda.com/tech/honda_engine_codes.html
they had s and si in 93.. vtec was introduced in 94+
hope this helps:
the 93 s comes with a D15B7 which is non vtec
the 93 si comes with a D16Z6 which is vtec
so if indeed dats the stock motor then its a D16Z6 which is already vtec.. and to answer his question, the motor for a 95 civic si is a B16A2 which is the same motor they put in the 96 del sol si vtec
SolidHollow
15
Sep 13, 2015 11:18 AM
Touge
Sep 1, 2015 11:25 PM
PierrePierre
Aug 12, 2015 02:42 PM
