Can somebody help diagnose my problem?
1. The CEL is on
2. While in cruising speeds abt 2500rpm in EVERY gear, the car starts to jerk and buck pretty violently. While accelerating it seems normal. Decelerating seems normal.
3. No apparent loss in MPG - Maybe a LITTLE.
Im pretty mechanical so if theres anything a mechanical guy can to do help diagnose the problem(like take some stuff apart and check and put it back. I am able)
I'm gonna take it in to get it checked on sometime in the near future but can anybody help give me peice of mind and what I am prepared to hear from my mechanic?
I searched. I got a lot of "shaking" but what I discribed it as jerking/bucking fits the discription 10000 times better
Thanks for the help in advance guys
Re: Can somebody help diagnose my problem?
can you check your spark plugs? if they are not firing on all of them the engine jerks at certain rpm and loading. the spark plugs which are not firing are usually black. how many miles u got on ur car?
Sounds like you're running on 3 cylinders. Captain obvious dictates you can solve the problem easier by scanning the code. You probably need an injector, a spark plug or a coil.
Currently having the same problems (jerking, shaking when accerlerating) in my '03 Civic EX manual. Changed all four spark plugs (NGK's per spec.) a while back and the problem went away for a couple of weeks. Now, it's back...going to check the EGR next.
you sir most likly (90% sure) have a miss fire you need to find out what teh cel is ... if the problem goes then comes back after plugs are changed you moght have a coil problem...
The Autozones out here in CA no longer does this...liability issues. Before I changed the plugs, the CEL was on and had the following trouble codes: P0300, P0303, & P0304 (cylinder misfires). Now, when the car shakes, the CEL blinks occasionally and does not stay on. I will need to check again to see if there are any stored codes.
could be blown headgasket leaking coolant into the cylinders. or a fuel injector problem. maybe one of em is clogged or not spraying a mist like it should.
OK...the jerking, hesitating is progressively getting worse. The CEL is back ON again and the following trouble codes were detected:
P0301 - Misfire detected in Cyl. 1
P0303 - Misfire detected in Cyl. 3
P0300 - Random misfires detected
All four plugs were recently replaced (NGK's) <2 months ago. I will remove and check them again this weekend. Very frustrating...
make sure that they gap them to you motor. if not changing them again will do nothing. i have had some friends that got plugs and they never asked to gap them or they never asked you if you wanted them gapped. when you go just ask can i have my sparkplugs gapped. then let me know what happends.
manuel
manuel
The NGK's came gapped to the vehicle's specs. Trying to re-gap them will damage the electrodes.
This jerking, shaking thing is occuring in a LOT of Civics out there and I am quite dismayed a solution has not been found.
i never said REGAP YOUR SPARK PLUGS. if every auto zone and advance auto parts stores sold pregaped spark plugs for the specs on every car, truck, suv, van, busses and so on not to say every motor size then all they would sell are spark plugs. why do you think they sell the tool to gap them yourself. im not saying that you dont know what you are talking about im just saying what i know. and i have ngk uritium spark plugs in my civic and they had to gap them for me and im going on 3 and a half years with them and no problems.
manuel
manuel
I'de like to know this myself. I have a 98 accord ex that is doing the misfire thing with the same exact codes, but the missing ONLY happens during idle. I did a leakdown test and found some minor issues, but this issue just started suddenly and not progressively. I hope more input is given on this......this could get interesting.
usually valves being out of adjustment will not cause major issues. injectors need to be sent off for cleaning.
http://www.cruzinperformance.com/fuelinj.html
just get the plugs right. then like gearbox said you might have to change your injectors but before i would do that i would pass a bottle of lucas fuel injection cleanner in my car. 1 it cheaper than new injectors and might fix the problem and save alot of time and money. when your gass is real low you mix it in your gas tank and then fill her up. because i have a vafc2 in my civic and we are trying to set the fuel for all my gears and sometime if we put too much or too little it would start to spudder but when im off of running it it runs normal. it also has a 2 step for me to set, we put it at 4000 rpm and it launches hard but when i get to past 4000rpm in 2nd it sputters like booop....booop....booop then i turn off the 2 step it runs fine because im not using no more or less fuel than i normally should be. thats why when i put my turbo on i just recently bought some rc 550cc injectors compared to my stock 220cc or 240cc injectors. try that and keep me posted, if that still doesnt fix it i have alot of friends that are honda certified tecs.
manuel
manuel
I re-checked all the plugs and connections to the ignition coils -- everything is tight. Pumped in a half-tank of Chevron's super unleaded and poured in a bottle of Lucas FI cleaner. Will report back in a couple of days...
It's been a couple of days already and the symptoms (jerking and hesitating when accelerating) have NOT come back, so for now, the half tank of super unleaded and bottle of Lucas FI cleaner seem to be working!!! Thanks, dude!
The problem came back after a couple of fill-ups since pouring in the Lucas. Also noticed that the heater is taking longer to blow warm air and it even fluctuates from hot to cold when the dial is turned all the way to the HOT position and the car has been running for a while.
Sounds like a head gasket to me, since the heating issue could be coolant related. Do you have any white, milky substance in your oil? Do a compression check and a vacuum check. If you have low compression on to adjacent cylinders it's probably a head gasket. Or, if you are getting oil on the electrodes on your spark plugs, you might have worn rings, which would also cause low compression, and the oil on the plugs would cause misfire/ fouled plugs.
manuel
manuel
Xuhme
21
Aug 7, 2023 03:40 PM
DVexile
Jul 2, 2021 05:25 PM
juror
Jun 9, 2015 02:15 PM
pantdino
15
May 13, 2015 02:22 PM
