Having A Problem W/the Pressure Pipe Befor The Blow Off Valve Popping Off.
Old Feb 24, 2007
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
MY TURBO INSTALL HAS BEEN COMPLETE. IM IN THE STREET TUNING PHASE ,BUT MY PIPE BEFORE THE BLOW OFF VALVE KEEPS COMING OFF DURING BOOST. I HAVE TRIED CLAMPING OVER AND OVER, NOTHING. I GET A FEW RUNS AND GET A HESITATION AND THE PIPE POPS OFF. IS THERE SOMETHING I SHOULD BE LOOKING FOR. I BOUGHT SOME T-CLAMPS AND SOME SILICONE HOSES AND IM GOING TO DOUBLE CLAMP THE AREA AND SEE WHAT HAPPENS ALSO GOING TO RUFF UP THE CONNECTING AREAS OF THE PIPE WITH SAND PAPER FOR BITTING INTO THE SILICONE.
IF ANY ONE HAS ANY IDEAS ,LET ME KNOW THANKS.
I ALSO WANT TO THANK EVERY ONE THAT HAS HELPED ME ALONG DURING THE TURBO INSTALL . THANK YOU...
Old Feb 24, 2007
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
also try spraying some hair spray on the inside of the coupler...that should help alone...ut good luck with it
Old Feb 24, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i dunno, turn down the boost just a hair til you figure it out? maybe a different type of connection? i dunno....
Old Feb 24, 2007
ST8RACE's Avatar
Im Only Running 6 Psi Of Boost Right Know. So I Dont Think Thats The Problem. But Thank You.
What Does The Hair Spay Due And Were Did You Get That Idea From . Just Wondering. Ill Try It I Have Nothing To Loose.
Thank You .
Old Feb 24, 2007
ronaldo9's Avatar
Worst comes to worst will it be a pain to weld that trouble spot or just get a new pipe that does not need a coupler there?
Old Feb 24, 2007
ST8RACE's Avatar
Has Any One Had The Need To Secure There Piping With Brackets . Or I Should Not Have These Problems Anyway. Well Will Try What I Have Know And I Will Read Any Ideas I Get Here As Well. Thank You
Old Feb 24, 2007
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
you could weld two nuts on the side of each pipe the thread a bolt in that should keep it on ....
Old Feb 24, 2007
Randyh's Avatar
Randyh will become famous soon enoughRandyh will become famous soon enough
Is there a bead on the ends of the tubing? You should not have any of these problems with only 6# of boost.
Just clean them both well and it should be fine. If there is no beads rolled on the ends of the tubing or weld beads you can take a pair of vise grips and make the ends flare out a tiny bit.
Later
Randy
Old Feb 24, 2007
C2i0v0i1C's Avatar
SuperMODrizd
get a smaller connecting hose. then use the Tclamps. also the bead statement is good. some pipes come with a circular lip around the end of the pipe for just these issues. if u dont have a lip...try flaring out the end of the pipe. gots to do something to create some resistance on the end of the pipe
Old Feb 25, 2007
tfnaaf's Avatar
BLDNPSI Mod
I bead welded all my pipes running 7psi for 2 years and have NEVER had a pipe blow off
Old Feb 25, 2007
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
yah mine will be gettin welded soon once im on 15PSI
Old Feb 25, 2007
skipbarber's Avatar
is the blow off valve opening?
Old Feb 25, 2007
ST8RACE's Avatar
thank you all for the help, I purchased some t-clamps and funny to say,but used hair spray. thanks for the tip. also purchased a new elbow for that connection. and all seems to fit very well.drove it today trying to get it tuned up alittle. found to have misfire problems while under boost.
used the non-fouler connectors to remove the ck engine light for the cat. converter codes . fixed the intake leak, for that ck engine light code. know i have misfire codes in all four cylinders. if any one has ideas let me know .again thanks for the help on my piping problem.
Old Feb 25, 2007
tfnaaf's Avatar
BLDNPSI Mod
how are you tuning it?
Old Feb 26, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
i have misfire codes on my car also. its very very random the CEL will turn on and off by itself. it could be a bad tank of gas. you are using the highest octane available correct? in the vegas area we only have 91. it could also be your spark plugs. i forgot what plugs i am running but they are ngk #7 heat rating, that is what a lot of my boosted friends and shops have been recomending me. i say try some octane booster or check the plugs. if that continues, retard ignition timing.
Old Feb 26, 2007
ronaldo9's Avatar
He can't retard the timing bc he has that TSI fuel system setup. Your best bet is colder plugs and a conservative tune running the highest pump gas you can get in your area. I get misfires too on all cylinders but I have an n/a cam. I only get it at idle but I'm going to try PCS to see if it can tune the idle better than emanage.
Old Feb 26, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
The first thing that I thought was weather or not your blow off valve is opening, or if it's not opening enough. Because concievelbly there should be no air pressure left inside of the piping as you shift. It would vent atmospherically. If you're blowing pipes off, that means you're retaining air pressure which in my mind could only mean two things: The BOV isn't opening/opening up enough, or your wastegate isin't opening soon enough. With a wastegate that is still allowing the compressor side to spin, results in Higher then desired PSI. Do you have a boost gauge? When you blow a pipe apart, what is it reading?
Old Feb 26, 2007
ST8RACE's Avatar
I Resolved The Pipe Problem. Its All Redone With T-clamps And Roughed Up The Pipes For A Better Connection. Know Im Battling The Misfire Problem..
Old Feb 27, 2007
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
My brother does the whole hairspray deal on his truck which runs up to 35 psi so I think that will do the trick.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
jc33312
May 12, 2015 03:17 PM
crowtoo
May 11, 2015 06:50 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
skywalker
Nov 8, 2001 05:04 PM
