what other parts do i need?
Old Feb 21, 2007
ryancivic's Avatar
ryancivic has a little shameless behaviour in the past
found a built ex head for a decent price the guy says its missing parts. (solenoid and cam oil seal or something) if i were to buy this and get a solenoid from honda or something do u think it would be ready to bolt on? Also would the valve cover from my lx fit on?
eBay Motors: HONDA CIVIC D17A2 1.7 VTEC REBUILT CYLINDER HEAD 01-05 (item 170080625360 end time Feb-21-07 15:55:46 PST)
Old Feb 21, 2007
TRIZ's Avatar
man, that thing is very clean!!
I dont know **** about internals, g/l
Old Feb 21, 2007
AmbulanceMonkee's Avatar
wtf is he talking about in that listing "D17A6"???? either way, that thing looks good, but i don't know if your valve cover will fit, and you need to get a controller for the vtec. also, you will need that solenoid, the wiring, and any seals not included. all in all, not really seeing this being worth it. what are you hoping to gaing by swapping heads??
Old Feb 21, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
https://www.civicforums.com/forums/1...p-ex-vtec.html
Old Feb 21, 2007
familycar's Avatar
that is a stock rebuilt head. you might as well save yourself $200 and buy a used low milage head that is complete. for the 7-10 hp youll gain it really isnt worth it unless you plan to build the motor. you WILL spend time adjusting the valves and mating it to the lx block as well as fine tuning. be prepared to spend about $1k to make everything work properly
Old Feb 21, 2007
vacivic2005's Avatar
vacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the rough
gluck
Old Feb 21, 2007
ryancivic's Avatar
ok well its not that easy to find a d17a2 head. honda wants 2200 for one (no fcking way) and the only one i could find is that thing on ebay. idk.
Old Feb 21, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
well if its 320 rebuilt and milled, thats pretty cheap. You need the solenoid, the cam position sensor, it looks like a cam gear, there's an oil seal on both sides of the cam, if its missing the cam plug, it may be missing the ring behind the gear too, you also need the water neck/EGR valve assembly from the passenger side of the head. that head is quite incomplete unless you have another EX head to swap some parts over from.
Old Feb 21, 2007
familycar's Avatar
you can find them here as well. take your time no need to rush and pay moe than its worth. that head is going ot end up costing you more than you think
mohawkboom
67
Aug 25, 2015 12:28 AM
Tim1959
Jun 3, 2015 08:15 PM
juror
May 26, 2015 06:35 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
