How bad is it changing the alternator on a 2001 EX?
Old Jan 26, 2007
Intercooler's Avatar
Intercooler is an unknown quantity at this point
My lights dim too much and my line voltage drops down to 11.3 volts with the 1700 watts I am running in my system. I want to add a high output alternator but don't know if it is a PITA to do it and the belts while there or not at the 53k mile mark. I am getting older and have less tolerance for busted knuckles and things that don't go right so I was thinking about paying to have it done. Anyone do this?
Old Jan 26, 2007
drunkenmagnum's Avatar
i have taken mine off twice. the first time took about 2 hours off and on. the second time took half of that. its not difficult just be sure u follow the diy. i wouldnt pay someone to do it unless u just dont have time to.
Old Jan 26, 2007
Where is the DIY on that? If the shop would only charge two hours labor that is $104. That isn't too awfully bad.
Old Jan 26, 2007
sl33pyriceboi's Avatar
yea, id say jsut pay someone to do it, its not worth ur time......
Old Jan 26, 2007
I found that DIY. I may try the big 3 first before taking this on. I am running 1700 watts and so far it hasn't been terrible but I dip into the low 11's on volts when it is hitting hard. Reading the threads about the HO alternators makes me think twice about going that route rather than the 3 plus a battery.
Old Jan 27, 2007
TeLLy's Avatar
Yes, it's an Acura EL
For the first time you do it, have handy a copy of the service manual (there's a copy floating around somewhere) and of course a good ratchet set. You should be able to do it in a few hours for your first time. It gets easier very time you do it, I've had to do a few now.
Old Jan 27, 2007
DragassD's Avatar
DragassD is an unknown quantity at this point
I replaced mine about 2 months ago and it was pretty easy. Have a good ratchet set with extensions.
Old Jan 27, 2007
Rufus's Avatar
I could do it on 30 minutes. It's just foreign when it's new. Pull off the PS pump, pull it to the right (the wheel on the P/S pump should sit right over the red reservoir cap) Next the alt has a few bolts holding it on as well as the plug. The bolts you can get to with a ratchet but you'll need to pull the d/s wheel off to get to the bottom bolt as well as the tensioner bolt. You'll see a wingnut on the front of the alt for adjusting the belt. Easy as pie
Old Jan 27, 2007
TeLLy's Avatar
Rufus I love your avatar. I have those headphones for my DJ work, now I feel sexy.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Jigee
May 9, 2015 11:18 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
