Help, 89 civic not starting
The only Wyoming Redneck on here
so my coworker has an 89 civicLX witht he d15 engine. he has 278,000+ miles on it. for some reason its not starting. we have replaced the spark plugs, the distributer. another co worker said that there is spark out of the coil and at the plugs. any ideas on what might be wrong? thanks in advance.
http://ackakaka.ytmnd.com
lack of fuel possibly. try taking the outlet line off of the fuel filter(to the engine) and cycling the key to on without cranking. you should see a signifigant amount of fuel come out.
does the engine sound like it's cranking normal?
well, we had fuel we could smell and see it on the spark plugs, we also tested the injector and it was good, we saw plenty of fuel. and we also used a fuel injector tester. i pulled the timing belt cover off and the timing bet was cracked in worn, changed that and it started right up. so thank you for your help.
Re: Help, 89 civic not starting
check the main felay.... underdash by ur left ankel.... its a small grey box held up with a 12mm bolt.... it has 1 plug with i think 9 wires going to it.... does the check engine light stay on after about 5 sec.? or take ur dizzy off and take it to an auto parts store the should check it for free
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
