Got some A/C Problems
Pwning Noobs 24/7
So recently my AC Compressor burned out due to my AC Condenser Fan not turning on to cool my AC Compressor, cost me $900 to replace it
, anyway my mechanic told me that the AC Condenser Fan is not turning on when the AC Compressor is on, and it might be that the ECU is not grounding the Fan...and he said i might need a new ECU
, my question is if i dont turn on the AC at all, will the compressor burn out again ? If i have the heat on does that affect the AC Compressor too ? Thanks
, my question is if i dont turn on the AC at all, will the compressor burn out again ? If i have the heat on does that affect the AC Compressor too ? Thanks Last edited by V-tek; Jan 15, 2007 at 03:29 PM.
If something in the AC system isnt functioning properly, your ac compressor clutches shouldnt be engaging. The condensor fan not working shouldnt have burned it out. Did you check all the fuses and make sure the fuse isnt popped?
mikemc422
Aug 9, 2018 05:41 PM
g4384063
May 30, 2015 11:21 AM
dinsum
May 28, 2015 09:30 PM
beveragemp
May 25, 2015 07:11 PM
