Stage 2, n/a, VAFC2 or emanage?
Old Jan 12, 2007
Matteo's Avatar
Matteo will become famous soon enough
Hey guys, im going n/a set-up and want to do: ex head swap, stage 2 crower cam + springs/reatainer kit, and ex header swap.
I know i can use a VAFC2 to do the ex head swap, but with the cam will that work well?...or is it better to use a emanage? Also are rsx injectors worth getting with the parts above put on?
Old Jan 12, 2007
ajhdragon's Avatar
7thgens official a$$hole
From personal experience the VAFCII is basiclaly useless unless you do a dx/lx to ex head swap. thats jsut to set the Vtec lo-hi/hi-lo engagement points. But as for tunning it does nothing. But the Emanage dosen't work as a Vtec engagement. But Its one of the best ways to tune the d17.
Old Jan 12, 2007
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
"An option for Honda VTEC cars will allow you to even adjust the VTEC shift point." directly from emanage product description...
Old Jan 12, 2007
Matteo's Avatar
so can i use the emanage only for the EX head swap and tune it? or what?
will the emanage really work better than the VAFC2 with the swap?
Old Jan 12, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Yeah, but you cant drop it low enough to make it worth while. I know from experience.
Use the emanage. as much as it sucks, it'll do much more for you than an AFC since you can actually go in and work on the maps.
Old Jan 13, 2007
Matteo's Avatar
so u are saying if i get a ex head swap, stage 2 cam, and spring/retainer kit all at ounce and take it to a shop...then all i need is just the emanage?
Old Jan 13, 2007
Matteo's Avatar
cmon guys, i want to make sure so i dont waste money on the wrong parts
Old Jan 13, 2007
Logan3024's Avatar
What do you mean it cant drop it low enough? It will engage where ever you tell it to
Old Jan 14, 2007
Matteo's Avatar
alright, thanks guys. i think im gonna go w/vafc2 because i AM doing a swap as well as the cam. im not looking for huge performance, just want some gains so extensive tuning and extra money for a emanage isnt for me
thanks again for the help
Old Jan 14, 2007
silver surfer's Avatar
silver surfer is an unknown quantity at this point
i have stage 2 crower cam n/a and tit spring and retainer set. brand new if you look on ebay in next 9 hours it will be item # is 300068667522. tried to sell on here but everyone just wanted to trade.
Old Jan 14, 2007
Matteo's Avatar
hey pm-ed u
Old Jan 14, 2007
yeh i know what you mean...and matteo its an option to use the vtec adjustment, i have emanage on my a1...
Old Jan 17, 2007
ajhdragon's Avatar
ive never had luck or have i ever seen anybody have very much luck with emanage and vtec settings on the d17. the AFC won't tune you for **** and the emanage is a pain in the ***.
Old Mar 1, 2007
TRIZ's Avatar
Well, how'd this go for you? Ever get it done? Hows stage 2 working for ya. I'm looking at doing the exact same thing, upgrading the cams and taking a head swapped D17 to stage 2, but havent came across anyone yet who has done this. But I've found you so far. So- tell me how it went, problems etc.
Old Mar 1, 2007
ronaldo9's Avatar
Stick to stage 1 Triz. The stage 2 is cool but its just impossible to get the car to idle properly w/o a stand alone. I'd trade my stage 2 for a stage 1 lol. But Im 80% sure I'll be buying ems.
Old Mar 1, 2007
familycar's Avatar
to take advantage of the higher redline you NEED EMS otherwise the higher reving cam is worthless
Old Mar 1, 2007
tougEMII's Avatar
tougEMII has a spectacular aura abouttougEMII has a spectacular aura about
^yeah seriously..if i was doing the stage 2 cam and head work...id at least attempt to raise redline to 8. thats where ull be getting lots of power. i rmbr watching a guy who did the stage2 cam on youtube..he posted it here on the site. he kept it at 7 redline and it looked like it still cuda gone more if he extended redline.
Old Mar 1, 2007
djmota's Avatar
first i want to say this statement is bs. It WILL tune your WOT fuel settings. Not the best, but I just dont like misinformation.
A stage 2 cam will improve your numbers from aorund 5500- stock redline When used with a decent set up of other parts. With my setup I could probably use another 500 rpm before the power starts to fall off, but it does even out right at the stock redline.
Old Mar 1, 2007
familycar's Avatar
the stage one will provide the same benefit as the stage 2 with out rev limiter controls. so if you dont plan to do EMS then save yourself the money for the springs and retainers and the tuning you have to do and just go with the stage 1
Old Mar 1, 2007
djmota's Avatar
agreed
Old Mar 1, 2007
tougEMII's Avatar
damn djmota...133 all motor. u hit 15.5 at lacr? or fontana or what. any vids of ur car ?
Old Mar 2, 2007
djmota's Avatar
the best i have done at lacr was a 15.7 the 15.5's where at pomona and fontana. Nah i don't have any vids. I should come up with a camera mount so I can make some.
Old Mar 2, 2007
TRIZ's Avatar
Camera setup? Check out my method of recording... (prob not legal at your track, I use it on backroads)
https://www.civicforums.com/forums/1...-mounting.html
BTW, I guess the orig poster isnt going to show in this thread- I will be creating a thread soon about my headswap+upgrading internals for comments and suggestions.
Old Mar 2, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
How bad is the idle???
Does it surg? Stall? What?
Old Mar 2, 2007
ronaldo9's Avatar
Idle is perfect in open loop but once you go into closed loop you will stall w/o a piggy back to pull fuel. It goes way to rich to keep an idle. I never had stalling issues until I got my test pipe. Taking out the cat seem to be causing more problems maybe from less back pressure I have no idea. Like I'll be driving fine and whenever I come to a stop light it goes too rich and cuts off. But the down side is if you take out so much fuel the ecu retards timing at least i think it does bc the car gets laggy and hesitates when you step on the gas.I'm gonna take out emanage for a week and see how the car drives w/o it. In a private convo with djmota he told me he has the same issue with stalling out and he just keeps his foot on the gas and uses the ebrake alot.. I guess for hills and stuff. Bottom line... EMS for the win
I do have a lil bit of surging at idle but Chris (Wilmnchris) was explaining to me thats the ecu trying to correct for proper air/fuel.
Old Mar 2, 2007
pon55's Avatar
"a lil bit of surging" LOL
It sounds like a chevy 350 with a roller cam
Old Mar 2, 2007
02BLKCIVIC's Avatar
Man Ron I had to move into a new house, and wasnt able to install my cam and cam gear.
But have you considered uying a VAFC2 to tune it???
Thats what Im going to use, but I dont know when Ill have the extra cash to install and re tune it.
Could be as long as a year...
thanks for responding back!
Old Mar 2, 2007
ronaldo9's Avatar
Sorry bout the move but no worries. It's not even spring/summer yet. You have plenty of time. I'm going to give the emanage another shot and see another tuner to see what they can do. I'll be purchasing a cam gear soon and hopefully that will mitigate some of the problems I'm having.
Old Mar 2, 2007
warpax's Avatar
warpax is an unknown quantity at this point
Hey Everyone,
I'm doing the same type of build. Actually, I have a complete D17A2 engine to swap into my 2005 LX. I bought the AFC Neo two weeks ago and installed it last week (minus VTEC control). I have all my parts now. Just got all the assembly parts today(Head bolts, Head gasket set, new plugs, new timing belt and water pump). I am at kind of a bottleneck right now because I'm stuck waiting for my head to be ported/polished (hopefully done in the next week). As soon as its done, the engine build can begin and hopefully be ready for late April/early May. I have an AEM adjustable cam gear, Crower N/A Stage 2 with valve springs and retainers, Megan 4-1 header, Random Technologies high flow catalytic converter, and vibrant performance catback system all ready to go. After reading these posts, Im hoping I don't have trouble getting it to idle with the Stage 2 Cam. Anyways, perhaps we should start a thread of the select few of us actually working on this build. Just a thought.
Happy Building Everyone
Warren
Old Mar 5, 2007
02BLKCIVIC's Avatar
Thanks for the support Ron!
Warren in my honnist oppinion yes you will have some idle and closed loop problems!
good luck sir!
