rear speake removal
I wil fix vBPlaza today
i dont know if its the same for the Si tho
https://www.civicforums.com/forums/2...-pictures.html
Heres a Lx coupe
https://www.civicforums.com/forums/2...peaker+removal
Heres a Lx coupe
^^ i disagree this is really really easy, i can do it in about 5minutes. use the first link DIY, to bad pictures down work, gj civic forums suck ***** more?
remove your rear seats first (10mm then 14mm socket)
remove the back top rear panels (top left/right)
remove both side panels (get teh screw first by the handle)
remove rear deck (i pushed the pins up with a wrench to make it easy to pull off)
best i can explain in the time i want to put forth helping you
The pictures didn't work long before this became "civicforums." They don't work because the server they were on does not have them hosted anymore.
Okay , finally got her done tonight, in the dark i might ad. I had a flashlight and an interior light. Otherwise would have had to wait another 3 days to do it. Couldn't have that since we are heading into the city tomorrow. Thanks for all the help and explanations, all went well without a hitch, didn't even break any clips at all taking the stuff in or out. I took my time and cleaned everything while it was out. I used the existing speaker wire til I get more equipment. I just took a spade connector and grinded it down a bit to fit into the stock plugs, for each wire. worked perfect and can easily put stock speakers back in. anywho, thanks guys, never would have thought that i would need to take all that stuff out.
mohawkboom
67
Aug 25, 2015 12:28 AM
DAC
Jun 18, 2015 10:00 PM
geoffm1234
Exterior DIY
Jun 3, 2015 08:18 PM
Flipg123
May 22, 2015 10:43 PM
