8th Gen 2006 - 2011.
New Engine break-in
Old Oct 3, 2006
tamia's Avatar
tamia is an unknown quantity at this point
Question New Engine break-in
Hi I'm new to the forum and I apologize in advance if this topic has been "done to death".
I just picked up my new 06 LX manual last Saturday and did some research about breaking it in (running-in to the Brits). I found this site on the net that suggests something very different.
I was hoping someone could take look and comment. Here's the link:
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
Old Oct 3, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
well you have probably driven it too far to make a difference so i would just cary on with normal break in process... if you haven't drven it far at all, go for it everything he sai8d maikes 100% sense to me and this is th emethod i will be using to break in my motors from now on.
Old Oct 3, 2006
pico's Avatar
pico is an unknown quantity at this point
"There's a very small window of opportunity to get the rings to seal really well ... the first 20 miles !!"
Guess Im screwed... I picked mine up with 40 miles on it. Hopefully my sales man ran the S*** out of it!
Old Oct 4, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
You'll Be Find Dont Worry About It
Old Oct 4, 2006
tamia's Avatar
Dyno
If this is correct, then you would expect Honda to perform this initial break-in on the dyno. They do dyno test each engine don't they?
Old Oct 4, 2006
Wadely's Avatar
Well I Donno About A Complete Dyno, They May Hook Up Some Schematic Bs But Not A Full Dyno
Old Dec 25, 2006
Kidekat's Avatar
Kidekat is an unknown quantity at this point
I can not imagine Honda performing a dyno on every engine they build. Maybe on the higher end models.
Just drive it normal.
Old Jan 25, 2007
SoK66's Avatar
SoK66 is an unknown quantity at this point
Honda does not dyno test all engines. They just build them and install them in the cars. Modern engine manufacturing is so precise there is no need to do this type of testing, which the brilliant Dr. Edwards Deming referred to as "mass inspection", a wasteful practice that is made unnecesary by eliminating variability in the build process. All manufacturers are well past this kind of sloppy practice. They will generally "batch sample" routinely to ensure nothing has gone awry in the process, however, and will make adjustments as needed.
The article quoted is basically a load of antiquated hogwash dating from the 40s & 50s, when engines were made out of crap and were lucky to go 40k miles without major repairs. Just drive it, you'll be fine.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Jeeves
General
18
Jan 31, 2002 08:18 AM
bluecoupe
Jan 23, 2002 05:50 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
