8th Gen 2006 - 2011.
PC Card Insert option in Navi Unit
Old Aug 22, 2006
mckoy's Avatar
mckoy is an unknown quantity at this point
Has anyone had any problems with this option.
I have purchase a Sandisk PC card Adapter (6 in 1 reader) and a SD Memory Card with no luck. I copied the songs to the card reader and sd card inserted in my laptop, then inserted in the pc card in the head unit and selected PC and nothing happens. It never even attempts to read it.
Anyone else have this problem?
Old Aug 23, 2006
sotony's Avatar
sotony is an unknown quantity at this point
what size memory card are you using?
Are you using an SD card larger than 2 GB? I've had no problem with the same combo--SanDisk 6-in-1 mated to a 2 GB SD card. It won't read my memory stick, but it doesn't claim to. Only thing I can think of is if you're using an SD card greater than 2 GB or one of the super-fast ones (please forgive the non-technical term) I think they work under a slightly different standard, and the nav system might not read them.
Old Aug 23, 2006
mckoy's Avatar
The size of the SD card is 512mb
Old Aug 23, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
512mb sd card would be 512 mb..... or megabyte if you dont know.. either way it's not bigger than 2gb... just read the owners manual and make sure you format the card propperly....
Old Aug 23, 2006
sotony's Avatar
hmm
hmmm. So that's definitely not the problem. Could be the formatting thing, though.
Just out of curiosity--If you hit the close button with the 6-in-1 in the slot, but without the SD card in the 6-in-1, will the display close? Mine gives an error beep and won't close if the card reader is in the pc card slot without a memory card stuck in it. Just curious. I just put an old 12 mb memory stick in there when i need the sd card for my phone. Incidentally--it won't read music off the memory stick. Maybe I should format it.
Old Aug 24, 2006
mckoy's Avatar
You might be right about the formatting. I will def. give it a shot. I also use the card (SD 512mb) for my digital camera. I will post results.
Old Aug 24, 2006
mckoy's Avatar
Talking Good NEWS!
I purchased a 1gb Compact Flash formated the card, added music and magic! The unit recognized and played my mp3s with no problem.
I'm using...
1 PC Card (PCMCIA) Adapter-Compact Flash Reader
1 1gb Compact Flash Memory Card (Brand is "Patriot memory")
Cheers!
Old Jan 27, 2007
Brooklyn's Avatar
Brooklyn is an unknown quantity at this point
I have a 2006 Civic and want to use the PCMCIA card option. Where did you purchase these items & what was the cost ? Also, I am not a savy computer person - How do you get the music onto the PCMCIA card ?
Old Mar 7, 2007
Tazz2000's Avatar
Tazz2000 is an unknown quantity at this point
First, you need the navi option in your car.
Second, you get a card reader for whatever type of memory card you buy, or get a 9-1 or 15-1 card reader with your card.
Third, copy the music using your computer.
Finally, put the card into the pcmcia adapter and place that behind the screen in your navi unit.
Old Dec 28, 2007
SpecialKPB's Avatar
'05 still rolling...
SpecialKPB will become famous soon enough
Re: PC Card Insert option in Navi Unit
thats an awesome feature, Navi is begining to look likes its worth the extra $$$$ now.....
-K
Old Jun 14, 2011
zoraiz7's Avatar
zoraiz7 is an unknown quantity at this point
does nave system of civic 2011 read sd card greater than 2gb ?? thanks for answering
Old Jun 21, 2011
08EX's Avatar
08EX is an unknown quantity at this point
I'm using an 8GB card on my 08 factory Nav without any problems.
Use a brand name card. I heard some no-name memory cards are troublesome.
Sandisk and Transcend make adapters for the PCMCIA to SD card or CF or whatever you want to use.
I heard the SDHC (high capacity) cards may not work.
Only plug a PC card (PCMCIA) adapter into the slot. Plugging anything else in will either get stuck or cause damage.
The Nav does not recognize all music formats. Incompatible files will be ignored. mp3 works for sure.
Low bitrate music files will be painfully obvious with the crappy Honda sound system.
bowie
Jan 21, 2018 09:29 PM
Jrosa
Sep 14, 2015 08:24 PM
Bricoleur
Sep 9, 2015 12:23 PM
Wiggles
Sep 8, 2015 05:05 PM
MamaBear2015
Sep 4, 2015 09:04 PM
