8th Gen 2006 - 2011.
Fog Lights Installed!!!
Old Jun 25, 2006
Hilorains's Avatar
Hilorains is an unknown quantity at this point
Took most of the day - here's the finshed mod.
If you want to try this here are some notes I made about the install. Step numbers are based on the Honda instruction I got from http://www.anythinghondaonline.com/.
Step 03 I used 2 flat head screwdrivers on each side of the clip to pop out the end clips.
Step 04 Had 2-5mm allen head bolts holding the grill to the front of the car.
Step 06 Had to cut out the entire hole, not just at 3 points; took a while to do. Be careful!!!
Step 07 Same as step 6.
Step 10 Good time to drill 3mm holes for lip installation. Wish mine had come in.
Bumper install complete. Did the work on carpet to minimize chance of damage.
Step 20 Loosen/unclip fender liner to give you more room to work around the washer reservoir.
Step 23 The ground bolt was the wrong size. Found one in my nut/bolts bin.
Step 30 Gotta pull hard.
Step 40 Reinstall 3 comnnector in reverse order - blue/white/green. Blue was tough to do.
Step 44 No retainer on my connector.
Step 50 Don't know why you need gloves. Popped out easy, almost hit my face.
Step 53 The footrest just pushes on.
FYI - 3mm is approx. 1/8" and 10mm is approx. 3/8"
Let me know if you have any questions.
Old Jun 25, 2006
CharlieLink's Avatar
CharlieLink is an unknown quantity at this point
Great Job
Thanks for the photos, the hints, and the story! It looks really great.
Now, was that your Civic or your wife's? And do you plan to do the other since you're so good.
Old Jun 25, 2006
pico's Avatar
pico is an unknown quantity at this point
Nice job! I think they really add to the look of the front. I went the lazy way and had they dealer do it.
Old Jun 25, 2006
Hilorains's Avatar
Thanks. Out of curiosity, how much did it cost to have the dealer do it.
Old Jul 12, 2006
civic_dx-g's Avatar
civic_dx-g is an unknown quantity at this point
i presume that these are the factory lights?
how much cheaper was it to buy the kit than to get it done at the dealer?
Old Jul 12, 2006
Hilorains's Avatar
Purchased the factory lights for $294 off the internet including shipping to Hawaii. I checked a local dealer and it would have cost me $690.56 to purchase and install the lights. The DIY saved me almost $400!! Guess I should get something else with my savings.
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
