Broken side mirror - can I use glue to fix???
Old Dec 6, 2006
drcivic's Avatar
drcivic is an unknown quantity at this point
Hi,
The whole passenger side mirror piece was busted off my 2001 civic lx the other day. I was wondering if I'd be able to just glue the plastic back together with automotive goop or something if that would hold up. Or should I just get a whole side mirror piece? Any recommendations of glues or experience is appreciated!! Thanks.
Old Dec 6, 2006
PunkingCivic's Avatar
I need TP for my bunghole
I would hit up ebay and just get a new one. There checp and the repair will probibly look ghetto, IMO.
http://motors.search.ebay.com/search...ge=search&fgtp=
Old Dec 6, 2006
CraigW's Avatar
I have a lot of faith in Goop brand glues. But... I think you should replace it the unpainted/power mirrors are reasonably priced IMO.
Old Dec 6, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
i also vote replace it via ebay... its way easy to do and they are pretty cheap on ebay
Old Dec 6, 2006
FALKEN's Avatar
Civicforums Junkie
replace it
Old Dec 6, 2006
twinbo's Avatar
twinbo is an unknown quantity at this point
I say replace too, mine was an unpainted, power mirror and it only cost me $100 brand new from Honda. I bet you could find one at a wrecker for half that. Try www.car-parts.com
Old Dec 8, 2006
cb450sc's Avatar
cb450sc is an unknown quantity at this point
ISomeone kicked off my mirror a year and a half ago - I have a 2003. The outside housing was not damaged just the support and brace. I used an epoxy glue and it has been fine.
Old Dec 8, 2006
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
If it is the internal black structural plastic, then use ABS glue from any home improvement store. I'm not sure if the exterior shell of the mirror is made of ABS plastic also. Check for the stamping imprint "ABS" inside the mirror shell. If it is, then ABS glue will work on it too.
Old Dec 8, 2006
estebomb_ftw's Avatar
Putting glue on your car? Are you trying to get on Pimp My Ride? haha
Buy new ones off ebay.
Old Dec 9, 2006
cb450sc's Avatar
You can't even tell that it has been glued even when you look close up!
Erndog81
Oct 31, 2015 03:01 PM
Blazz
May 25, 2015 10:56 PM
MamaBear2015
May 3, 2015 02:17 PM
SugarRay
Dec 6, 2001 05:17 PM
