installed coilovers...now have a problem
Old Nov 20, 2006
MotorWeb EM2's Avatar
MotorWeb EM2 is an unknown quantity at this point
right after i installed my k-sport kontrol coilovers, i went to test them and my steering wheel is off. when the car is moving straight the top of my steering wheel is facing the 2 o'clock position. like to the right. i dont understand why it is like that. i think my wheels need to be alligned too but will getting them aligned fix my steering wheel problem or no.
Old Nov 20, 2006
civic_04's Avatar
civic_04 is an unknown quantity at this point
get an alignment and tell them your steering wheel is off, they should be able to fix it at the same time
Old Nov 20, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Yeah, you need to get the front re-aligned anytime you change out suspension parts.
Old Nov 20, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
what they said... it will run you $50-$100... if you can find a place that does "lifetime" alignments.. its ALWAYS worth the extra $50 or so..
Old Nov 20, 2006
jovenilleb's Avatar
jovenilleb has a little shameless behaviour in the past
I just installed a maegan coilover spring. Its the same thing happened to my car.I went to tire kingdom and align it in an hour. Its all straight now. It will cost you in tire kingdom 100 bucks for a 1 year alignment.
Old Nov 24, 2006
loosha808's Avatar
loosha808 is an unknown quantity at this point
how do you like those coilovers? how's the ride and adjustability on those?
Old Nov 25, 2006
charcoalex's Avatar
charcoalex is an unknown quantity at this point
anytime you do suspension work you need an alignment when you took the tie rod end off the stock suspension and put it on the coilovers it messed up your alignment. the same thing happened to me when i put my k sports on just take it to your local alignment shop and just get an alignment and you'll be straight.
Old Nov 28, 2006
BiggyQ's Avatar
BiggyQ is an unknown quantity at this point
anything done to the suspension usually requires an alignment to be done. So even changing your rim size requires an alignment.
4 banger
Jun 5, 2015 01:44 AM
beveragemp
May 25, 2015 07:11 PM
Youshoe
May 22, 2015 09:36 PM
PimpBot5000
Nov 26, 2001 07:15 PM
Flatlander
Nov 16, 2001 05:38 PM
