Engine Noise!!! Gonna need your advice / expertise 7thgeners!
Old Nov 6, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
Red face Engine Noise!!! Gonna need your advice / expertise 7thgeners!
well, i think i have engine problem but not sure. it may be the clutch.. anywho.. everytime i rev (pressing gas pedal and iam in neutral or even driving) its making some kind of clanking noise (clak clak lol) over/around 2k-3krpm, it was actually doing that before when i change to aftermarket header but it went away (and that noise went away when i did the PCM ECU RESET).. now i was thinking i might just need to do the PCM ECU reset but i dont think it has something to do with it at all. unfortunately its making that same noise agian (when i switch to stock header)
Old Nov 6, 2006
com'n expert peepz!
Old Nov 6, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
so it only makes the sound when you use the stock header? or is it that you cant hear it after you put the aftermarket header on? sounds like a valve tap which is common. they may need to be readjusted.
Old Nov 6, 2006
well i put my aftermarket header and was no sound... but when i put my stock.. like a day or two, it started making that noise.. anywho, what is a valve tap? and you said is common... is it possible for me to adjust or i need to go to a car shop? i have manual trans btw, may thats 100X more common lol
thanks for the rep bro.
Old Nov 6, 2006
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
I have the same problem.
Old Nov 6, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Well if its happening when you are revving and its not more like a ticking sound, it may just be a rattle coming from the engine bay. Could be a loose heatshield, who knows! Gotta isolate where its coming from. If you are not noticing anything strange with the engine itself like bad vibrations or the performance has gone down significantly, you should be ok... especially since you probably dont ahve that many KMs on your car... Unless you beat it to **** lol.
Old Nov 7, 2006
dru106's Avatar
ThE CoRRupToR
Yup you said it!! Most likely heatshield!!
Old Nov 7, 2006
BigE19's Avatar
Well my motors been through hell and back. Turbo, popped head, and I constantly rape the b!tch i'll take a look for a lose heat shield. Thanks for the heads up
Old Nov 7, 2006
huh.. my heatshield is fully tightned thoe.. this morning the sound kinda went away and alil later, its making that sound again.. but not as loud as yesterday... prolly tomorrow it'll go away complete, it just got some flu lol
Old Nov 7, 2006
SOHC_VTEC_pwr's Avatar
SOHC_VTEC_pwr is an unknown quantity at this point
Is the check engine light on???
Old Nov 8, 2006
familycar's Avatar
sounds like a exhaust leak. it can make a patter sound when you step on the gas. also if it goes away or doesnt do it as much when the car is warm its another sign. you might have a cracked stock manifold. that is what happened to mine and tht is why i originally did the exhaust conversion. remember when i said i was having my neighbor weld the stock manifold. he was laying a bead over the crack.
it especially sounds like that could be the issue if it went away with the obx header install and is back with the stock manifold in place.
start the car and rev i tfrom under the hood. see if you can pinpoint where the noise is comming from and what kind of noise it is making. if its a patter or a tick rather than a clack then i am pretty sure that is your problem. or you may have a piece of the cat screen stuck in the cat. either way if the stock manifold does it and the header doesnt its obviously a manifold problem
Old Nov 9, 2006
Ic, I actually found out 2days ago whats making the noise.. i actually lost a bolt on my stock header when i installed it and there's like little opening lol! so found a replacement for now but i have to buy the exact same one... dang, couldnt imagine how sensetive it was.. anywho PROBLEM SOLVE!!!
thanks for those of you helped!
Old Nov 10, 2006
familycar's Avatar
i new it was an exhaust leak. you did too much work on it lately for it to just appear and not be that!!
Old Nov 10, 2006
true. .funny how one screw can make that noise lol!
Jigee
May 9, 2015 11:18 AM
CurryBomb
May 8, 2015 10:16 AM
cloudguy
Apr 28, 2015 05:02 AM
inarschenk
South
Apr 18, 2015 04:29 PM
smmahan
Apr 15, 2015 08:17 PM
