Crappy Honda door lock actuators
I know a lot of people are having problems with their door locks dying on them. There is no aftermarket solution so we're stuck buying the parts from Honda. Only problem is that labour charges are brutal at the dealerships and some of us can't spare the time to work on our cars.
I just got my driver's side door lock actuator (OEM) replaced today at Selective Sound in Mississauga. The work was done very quickly and I got a wicked deal. If you guys need to fix your doorlocks, I strongly suggest you call Davis (905 826-8998). SS has a great reputation on TCC forums.
I'm in no way affiliated with this shop, just trying to save you guys a couple of bucks. Now if I could find someone to fix my windshield washer sensor for cheap...
my lock safety is broken (lock will work now with door open), i have a bad rattle from the door, and i can no longer use the key to lock/unlock the driver side nor can i even push the lock down. but the power lock still works lol.
When I bought this car used, I told the guy I was looking for "a compact japanese car (ie. civic, lancer, impreza, sentra) with a manual transmission, and manual windows and locks." He looked at me like I was f'ing crazy. He said "why don't you want power anything?" Well, I had so many issues with the power windows, and locks on my last car, I didn't want anything to do with them on this car. Besides, I'm 6'3", so I can reach over and roll down my passenger window while keeping a hand on the wheel and still see where i'm going over the dash. The lack of issues with manual windows and locks still doesn't make up for the lack of V-TEC tho.
Re: Crappy Honda door lock actuators
Hi Peeps,
The door lock actuators are very easy to fix. Honda dealers don't care for you to know this.
Few people know that the 12v mini motor that powers the actuator is worth about $5 max from places like Sayal Electronics, The Source/Radio Shack or Surplus Hobby Supply stores etc. and if you are mech. inclined you dissasemble the actuator (5 small screws) and replace the motor. Usually the brushes wear out or the motor gets rusty and seizes. Seldom have I seen the plastic worm gear set in need of replacing.
The little motors can be found as Johnson Motor PMDC motors KF243G-101 or the original Mabuchi Motors 12V DC motor.
Once you take out the actuator for the door remove the 5 small screws that hold the assembly together. The 2 wires for the motor usually yellow with red stripe and white with red stripe plug into the motor and can be easily removed with a small flat tip screwdriver. Lift the motor and plastic worm gear assembly out of the casing and pull off the motor.
leave the large round gear and lever arm in place as it is spring loaded and can be a bit of a pain to reassemble if removed from it's centre pin mount.
If it needs to be changed the pin on the leaver arm needs the end to be squeezed a bit and then it can be pulled out to disassemble the arm gear assembly.
The small coupling must be pried off the splined end of the motor and can be pressed on to the shaft of the new motor.
Reassemble the complete actuator and you have just saved your self some spare change.
hope this helps.
Pics are at
Pic1
http://www.box.net/shared/ggzv2nr899
Pic2
http://www.box.net/shared/nhpq22aonm
pic3
http://www.box.net/shared/8i6ysse464
Pic4
http://www.box.net/shared/e7hz02qxxu
Pic5
http://www.box.net/shared/kqqfnilpoq
Pic6
http://www.box.net/shared/nvxt7u8b26
Pic7
http://www.box.net/shared/oydumhtf7t
Just did 98 civic si coup DrLk. actuators and Acura 1.6 El's.
piece of cake.
Most all Honda products the actuators are all quite similar.
Regards and Hi to all.
My first time out here
hope this helps.
Pics are at
Pic1
Pic2
pic3
Pic4
Pic5
Pic6
Pic7
piece of cake.
yhanks for the info this will help. But Do you know how to ghet at the actuator, there is no room. Would it be the best to take mthe whole lock mechanism out.ould appreciate your reply
Thanks
Thanks
Wiggle / Slide it down a bit and tilt it out of the way.
Then you can see the and access the 3 small Phillips head screws that hold the actuator to the door lock assembly.
Hi Peeps,
snipped
snipped
piece of cake.
snipped
snipped
piece of cake.
I can't budge it.
I've tried torching it, hammer through a vise with a small drill bit etc.
Won't move.
Help!
MamaBear2015
May 3, 2015 02:17 PM
