Our cars NO CASTER?
Old Oct 17, 2006
nick82006's Avatar
nick82006 is an unknown quantity at this point
Question Our cars NO CASTER?
I went to get my car alignend today and i pick it up and it is still pulling to the left. So i go back and ask the guy , whats up? and he says that on our cars there is no caster adjustment, thus it being off and pulling.....and he cant do anything about it? Is he jerkin my chain or telling the truth?
Old Oct 17, 2006
realitycheck's Avatar
realitycheck is an unknown quantity at this point
I think you got ripped, my guys always adjust both my toe and camber.
I could be confused on the caster part though.
Old Oct 17, 2006
Maverick_1337's Avatar
Maverick_1337 will become famous soon enoughMaverick_1337 will become famous soon enough
our cars dosent pull to the left or right so i would go back again
Old Oct 17, 2006
Zzyzx's Avatar
Autocross Junky
There is no stock Caster adjustment, Just like there is no stock Camber adjustment (Bolt slop asside).
If you want to adjust caster, your looking at either buying a set of K-mac Camber+caster plates, Fabricateing up a set of caster plates, or Slotting the strut towers. You may be able to more evenly align caster if you adjust the position of the sub frame (bolt slop) but thats kind of out of the relm of an average alignment shop.
Old Oct 17, 2006
robbclark1's Avatar
Retired suspension supermod.
You can do it in your driveway though, right?
Old Oct 18, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
haha, i'm fed up with trying to find camber plates and caster options.... i might .....end up slotting something!!! what zzyzx said
Old Oct 18, 2006
See I told you I could be confused about the camber part, LOL.
Old Oct 18, 2006
drive_fast_dail's Avatar
drive_fast_dail has a little shameless behaviour in the past
Check your lower control arm bushings, those are a weak spot for wear on the car. I got a 2002 with 50k miles and they are looking pretty bad but still havent messed up my caster. I would try and take it to an alignment place you know is good, but those bushings could be effecting the caster.
Old Oct 23, 2006
blustrek01's Avatar
blustrek01 is an unknown quantity at this point
if your car is pulling then you have a camber and toe issue. if you camber is off bad then just a grove in the road can pull the car in that direction. if you have a toe issue then the the car will react in the came manner but more extreme. the guy telling you that you have a caster problem is full of it. the caster was set at the factory, when they designed the car. if you look at the angle at the tower and down to the lower control arm , that is the caster angle. with out plates there is no way to adjust it. besides you would want to change the caster unless it is a full race car.
blustrek01
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
