cruise control still not working
i tested all the inputs / outputs on the CC unit and it still wont engage. heres what i checked:
clutch switch works
brake switch works
set resume cancel works
power switch works.
CC light in dash works.
all fuses are good.
i took the actuator w/ computer out and everythign looks fine.
what do i do? where can i get a actuator / computer for it less than the dealer?
clutch switch works
brake switch works
power switch works.
all fuses are good.
i have the same problem. with the cruise control button pushed down the cruise control doesnt work. when i press any of the buttons except cancel on the cruise control the light comes on and says its working but it doesnt hold my speed.
i had simular problem. It would turn on and run for a little while but after that it would shut off. I had to push dash button on and off and it would work for a while again.
I tracked down AC control box (under the dash, driver side), repalced it and it works like new.
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
