Screwed up lug bolt....
Can a lug bolt be re-threaded? I can't believe that transform spoilers stripped my lug bolt. they installed my springs and were the last ones to re-install my rims. Now the bolt either has to be replaced or re-threaded.
front or rear? on the drums its very easy, just pull the drum off hit the old stud with a hammer and air gun the new one in, front yout have to take off the caliper and sometimes the disk and then air gun the stud in...stil not very hard though i do it all the time at work
well the way we do it is with an air gun and a few washers, te fronts are a pain in the a$$ i would deffinately go make them do it, they messed it up just tell em that and they will fix it for you
ThE CoRRupToR
well its not hard if u have the right tools!! If its the front youre gonna need a slide hammer and remove the axle nut so u can pull out the hub a little till u have enough space remove the stripped stud.....In other words have the shop do it...haha
you can also use a press to press out the hub and then the studs... but you are gonna have to take out the whole knuckle for this... i've done it many times on my old cars and friends cars... but thats only cause i have all the tools AND i have a press at home.. be best to bring back to the shop.. using a airgun is not the right way to put in new studs. its possible... but it's also possible to strip or stretch the new stud... do it right and have a machine shop press it in for you or just let the shop do it...
ricer_em2
May 11, 2016 08:09 PM
SidCivic
Oct 3, 2015 06:00 AM
redcloud
Sep 7, 2015 01:45 PM
ballmich
Jul 9, 2015 11:59 AM
