Screwed up lug bolt....
Old Oct 10, 2006
kornsined's Avatar
Can a lug bolt be re-threaded? I can't believe that transform spoilers stripped my lug bolt. they installed my springs and were the last ones to re-install my rims. Now the bolt either has to be replaced or re-threaded.
Old Oct 10, 2006
skipbarber's Avatar
just replace the stud...dont try to rethread it.
Old Oct 10, 2006
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
make the shop replace it because its thier fault
Old Oct 10, 2006
kornsined's Avatar
how difficult is it to replace the stud?
Old Oct 10, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
front or rear? on the drums its very easy, just pull the drum off hit the old stud with a hammer and air gun the new one in, front yout have to take off the caliper and sometimes the disk and then air gun the stud in...stil not very hard though i do it all the time at work
Old Oct 10, 2006
kornsined's Avatar
it's the front. is an air gun necessary? I don't have one.
Old Oct 10, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
sl0wEM2 has a spectacular aura aboutsl0wEM2 has a spectacular aura about
Front is going to be a pain in the @ss to do yourself even if you have the tools. So I recommend taking it back to the shop and make them fix it.
Old Oct 10, 2006
burke420's Avatar
The World Is Yours!
i mean i know that Dsicount Tire CAN re-thread studs that are bad...just tell them... but that all i know... i work there and all!
Old Oct 10, 2006
well the way we do it is with an air gun and a few washers, te fronts are a pain in the a$$ i would deffinately go make them do it, they messed it up just tell em that and they will fix it for you
Old Oct 10, 2006
dru106's Avatar
ThE CoRRupToR
well its not hard if u have the right tools!! If its the front youre gonna need a slide hammer and remove the axle nut so u can pull out the hub a little till u have enough space remove the stripped stud.....In other words have the shop do it...haha
Old Oct 11, 2006
FERIOHHHHHHHHHH's Avatar
FERIOHHHHHHHHHH will become famous soon enough
you can also use a press to press out the hub and then the studs... but you are gonna have to take out the whole knuckle for this... i've done it many times on my old cars and friends cars... but thats only cause i have all the tools AND i have a press at home.. be best to bring back to the shop.. using a airgun is not the right way to put in new studs. its possible... but it's also possible to strip or stretch the new stud... do it right and have a machine shop press it in for you or just let the shop do it...
Old Oct 11, 2006
well i have put in many studs with an airgun, washers, anti-seize and a lug nut and hav not stripped one new stud
Old Oct 11, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
u can re-thred a stud. but just have the shop do it or make them get a new 1 and put it in...
Old Oct 12, 2006
kornsined's Avatar
if i drive it to the shop is it going to be safe? Some highway driving involved.
Old Oct 12, 2006
kornsined's Avatar
yes only one is fu@ked. On top of that the gorrilla nut is stripped inside too. so that's garbage rendering the whole set useless.
Old Oct 13, 2006
airgun workssss... butttt ive seen ppl stretch the stud b4 and is it really worth it?!? it dont cost much to bring to machine shop to press it in.. no more then 5 bucks... i know cause i work at one!!!
ricer_em2
May 11, 2016 08:09 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
redcloud
Sep 7, 2015 01:45 PM
ballmich
Jul 9, 2015 11:59 AM
