Hope someone can help me!!
ok i drive an 05 civic and i have projector headlights and the left projector shines higher than the right one..Does anyone know how to adjust to projector?
look in the back, there should be a gear or screw you can turn to adjust the headlight. it helps if you park 25 feet from a white wall and do it. cover one side up while you adjust the other side. and aim them on the wall so the beam is about 2 inches lower than the middle of the headlight.
ya there is usually two for each lens like 4 total then since it has separate hi beams. you gotta be next to a wall tho to see what its doing. turn some and see what happens.
ya try it out. i know hi beam doesnt need adjusting but some projector have them anyway. you can also slightly adjust them by loosening the top screw holding on the headlight, pushing down the headlight, and then tighten the screw while holding it.
jdh022764
18
Nov 3, 2015 06:44 AM
Scout1
Oct 5, 2015 01:33 PM
Sep 27, 2015 11:33 AM
OptimisticWay
Sep 18, 2015 09:37 PM
