Hope someone can help me!!
Old Sep 2, 2006
Honda05's Avatar
Honda05 is just really niceHonda05 is just really niceHonda05 is just really niceHonda05 is just really nice
ok i drive an 05 civic and i have projector headlights and the left projector shines higher than the right one..Does anyone know how to adjust to projector?
Old Sep 2, 2006
look in the back, there should be a gear or screw you can turn to adjust the headlight. it helps if you park 25 feet from a white wall and do it. cover one side up while you adjust the other side. and aim them on the wall so the beam is about 2 inches lower than the middle of the headlight.
Old Sep 2, 2006
Honda05's Avatar
I saw a grey screw in the back that i could turn but i wasnt sure if that was it..Is that wat your talking about
Old Sep 2, 2006
ya there is usually two for each lens like 4 total then since it has separate hi beams. you gotta be next to a wall tho to see what its doing. turn some and see what happens.
Old Sep 3, 2006
Honda05's Avatar
See theres only one grey screw you can turn..I dont think you have to adjust the high beams..But i'll give it shot..Thanks
Old Sep 3, 2006
ya try it out. i know hi beam doesnt need adjusting but some projector have them anyway. you can also slightly adjust them by loosening the top screw holding on the headlight, pushing down the headlight, and then tighten the screw while holding it.
Old Sep 3, 2006
Honda05's Avatar
ok cool thanks alot
bowie
Jan 21, 2018 09:29 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Scout1
Oct 5, 2015 01:33 PM
Sep 27, 2015 11:33 AM
OptimisticWay
Sep 18, 2015 09:37 PM
