where to ground indiglos?
Old Mar 12, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
Where did you ground your indiglo lights?
Old Mar 12, 2002
Desi's Avatar
Desi is an unknown quantity at this point
- try these two places:
- all i did was remove the center trim piece with the cigarette lighter and you will notice a black wire hooked to a bolt. that's where they grounded the cd player. just wrapped the wire with that same bolt and thats it
- you can also ground the wire under the bolts under the steering section. just make sure its touching metal
Old Mar 12, 2002
also which wire on the harness is the positive? there are a bunch of red wires....one red wire has little grey spots on it i tried that but it still didnt work. im having trouble i just dunno what to do to get this thing workin [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 12, 2002
FLY's Avatar
FLY
FLY is an unknown quantity at this point
just put into one of your fuses thats what i did but then again i may be ghetto
Old Mar 12, 2002
if i put it in the fuse box theyd be on all the time...i dont need them on all the time, only at night
Old Mar 12, 2002
01civic911's Avatar
01civic911 is an unknown quantity at this point
there is a red wire with a black stripe in the blue harness that goes into the left side of the gauge cluster, splice into that and the indiglos will come on everytime the parking or headlights are turned on as they are supposed to. As far as the ground wire, when screwing the cluster back in, wrap the ground wire around one of the screws and screw it in place. the cluster is screwed into the metal chassis, so that will provide a solid ground. I did this same method to my car about 9 months, they have not flickered or had any problems once.
Old Mar 12, 2002
well i did that..i tapped into the black/red wire...and grounded it ..... nothing. maybe theyre bad indiglos
Old Mar 13, 2002
2Hondaz's Avatar
2Hondaz is an unknown quantity at this point
Easy way to find out if they are bad is go touch the wires to the pos/neg on your battery. If you get nothing there, then something is wrong.
Old Mar 13, 2002
Quiksilver's Avatar
Quiksilver is an unknown quantity at this point
I grounded mine in a screw behind the fuse box. I'ts easy to get there and you don't have to remove anything.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Bricoleur
Sep 9, 2015 12:23 PM
