where to ground indiglos?
- try these two places:
- all i did was remove the center trim piece with the cigarette lighter and you will notice a black wire hooked to a bolt. that's where they grounded the cd player. just wrapped the wire with that same bolt and thats it
- you can also ground the wire under the bolts under the steering section. just make sure its touching metal
also which wire on the harness is the positive? there are a bunch of red wires....one red wire has little grey spots on it i tried that but it still didnt work. im having trouble i just dunno what to do to get this thing workin [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
there is a red wire with a black stripe in the blue harness that goes into the left side of the gauge cluster, splice into that and the indiglos will come on everytime the parking or headlights are turned on as they are supposed to. As far as the ground wire, when screwing the cluster back in, wrap the ground wire around one of the screws and screw it in place. the cluster is screwed into the metal chassis, so that will provide a solid ground. I did this same method to my car about 9 months, they have not flickered or had any problems once.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
260000milesgoal
Sep 25, 2015 07:41 PM
Bricoleur
Sep 9, 2015 12:23 PM
