Cold air intake problem!
Old Mar 11, 2002
5zigencoupe's Avatar
5zigencoupe is an unknown quantity at this point
Just wonderin if anyone out there has a problem with sucking up water threw there cold air intake! If so let me know if it make a vibrating noise in your exhaust and what may be the reason for that!
Old Mar 12, 2002
DJNuTzSaK's Avatar
DJNuTzSaK is an unknown quantity at this point
vibrating noise from the exhaust is probably caused by the rubber gasket where you bolt the exhaust to or your exhaust is just like that...
Old Mar 12, 2002
cro2k2civicla's Avatar
cro2k2civicla is an unknown quantity at this point
Dude if you were sucking up water for one you would have to be submerged and two your engine would have locked up by now. So unless you have a submarine modification on your ride maybe you should look at the exhaust gaskets for the problem... [IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 14, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
If you are worried about sucking up water, which you should be, then there is an easy solution. AEM bypass valve!! I have an injen cold air intake which runs right behind the front bumper. I have a xenon body kit which allows direct access to the K&N filter. ANyway, I was sucking up water left and right, which caused a major repair ($2100) for the car. So got the car back, installed the bypass valve ($50) and have had no problems since then.
Old Mar 15, 2002
iamboo's Avatar
Retired - SoCal FI Mod
APS... were you seriously sucking up a lot of water?? what kind of road and weather conditions were you driving it ??just curious...
ORskier
May 7, 2015 04:54 PM
JDock
Dec 5, 2001 11:52 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 25, 2001 09:38 PM
808specifxz
Nov 17, 2001 10:39 PM
Hobby2K
Nov 9, 2001 04:08 PM
