Help! Rear EP3 Brakes Problems
Old Aug 25, 2006
icetrap's Avatar
icetrap is an unknown quantity at this point
I just converted my rear drums to EP3 Disc
When I stop the car, the Front ABS keeps kicking in, even at low speeds. It's damn irritating, the juttering
However, the ABS does not kicks in during high speeds brake unless it's jammed braking. It happens only during moving to stationary situations
I am using front Preludes Disc brakes with normal Ep3 rear Disc. My Preludes are fine working with drums. It only happened when i converted to disc!
Anyone know's what the solution?
Old Aug 25, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
You did use the wheel speed sensors from the drums, right?
Old Aug 25, 2006
icetrap's Avatar
Not sure, I did it in a workshop
I'm a newbie in DIY besides doing my Cold Air intake.
I also suspect something to do with the speed sensors thingy!
Where do you plug this thing into?
my msn : icetrap@hotmail.com
Old Aug 25, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Read the sticky. It covers the use of the drum wheel sensors in the discs.
The use of the 11" rotors doesn't have anything to do with it. Mine work just fine with those fronts.
Fast fix... pull the ABS fuse.
Old Aug 25, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
I applaud you for going to rear discs from only a CAI DIY. Thats a pretty big leap in DIY'ing.
Old Aug 25, 2006
jester444's Avatar
Dain Bramaged.
jester444 is an unknown quantity at this point
DIY... The only way to go.
Old Aug 25, 2006
icetrap's Avatar
That's what I will do if it does not works. I will bring it to the workshop, jack up my car let them have a look at it!
Thanks so much for your help. Appreciated a lot!
Old Aug 26, 2006
icetrap's Avatar
Issue solved. The ABS Serrated Ring thaty looks like a gear from a dog box is positioned differently from the stock ES ABS Ring. The ABS sensor takes pulse readings from that gear. It did not read the ring properly when the car slowed down, so ABS kept kicking it
The workshop to help me solved the issue but doing a bigger ABS Serrated Ring and machined one on the spot. Hopefully everything works fine now on.
rhvic
May 22, 2015 03:06 PM
One_PeeJay
May 17, 2015 05:31 PM
Broadbeb
May 14, 2015 09:49 PM
CivicHX01
25
Nov 18, 2003 09:40 PM
Sparty
Nov 15, 2001 04:55 PM
