need help on my system!
Old Aug 24, 2006
jayjdlc's Avatar
jayjdlc is an unknown quantity at this point
hello to everyone! i have a JL1000/1 powering a JL10w7 (X2). every time a turn the volume up, the subwoofer will stop for a while and then goes on again, then stop.... it goes on cycle. i went to see the LCD on the cap. it reads 8.++ something when the subwoofer stops then it goes up to 12.++ and it will go on again. i have a HO alternator already and a stock battery. anybody knows what should i do? do i need a deep cycle battery or a bigger capacitor?
Old Aug 24, 2006
seems you need a bigger power cable for the wattage you're running.
Old Aug 24, 2006
sleekcivic2004's Avatar
sleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nice
it's also a possibility the amplifier could be going into protection mode when the volume is turned up...since it is having to do more work than when the volume is down. Check and see if the protection led comes on or the power led goes off (i can't remember which jl amps have). With it being a high end jl amp though i highly doubt it.
Old Aug 24, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
that's what i'm thinking too, or bad ground. what size wire you got for power and ground, where is your ground, and is the ground making good contact?
Old Aug 24, 2006
jayjdlc's Avatar
thanks to the responses.
thanks to the responses. i dont think it goes on with the protection thing on the amp because i dont experience it until after an hour. after that, when it starts to stop, it goes on a cycle. as what i think, it stops for 3 seconds then recharge then plays for 3 seconds again.... do you think i should just take out my capacitor? or buy a deep cycle batt (stinger)?
it just stop after an hour if the volume is too high. but when the volume is just fine, i dont experience it.
Old Aug 24, 2006
jayjdlc's Avatar
more...
Old Aug 24, 2006
05reverb's Avatar
power and ground wire size? how is the cap wired?
Old Aug 24, 2006
jayjdlc's Avatar
im not sure how the cap is wired and also the size of the wire. i just brought my car to a decent shop and they were the one who installed everything. anyways, how should the cap be wired? i will check on it tomorrow?
Old Aug 24, 2006
if it doesnt do it right away, it sounds like the amp is just overheating. can you ventilate it when this happens and see if it goes away?
Old Aug 24, 2006
jayjdlc's Avatar
but how do i know if the cap is wired correctly? batt to cap, cap to amp. is that right?
Old Aug 29, 2006
02SILVEREX's Avatar
02SILVEREX has a little shameless behaviour in the past
According to JL's website:
""My amplifier shuts off once in a while, usually at higher volumes" -
Check your voltage source and grounding point. The R.I.P.S. power supply is rated to operater with source voltage between 11 - 14.5v. Shutdown problems at higher levals can occur when the charging system voltage dropes below 10-volts. These dips can be of very short duration making them extremely difficult to detect with a common DC voltmeter. To ensure proper voltage, inspect all wiring and termination points. It is also a good idea to improve the vehicle's factory ground wire and termination point. Grounding problems are the leading cause of mis-diagnosed amplifier failures."
You may also want to contact them (JL) to see how they would wire the subs from that amp. I know it is their suggestion to use a 500/1 for a 10W7. I don't know about using a 1000/1. It is a MONO (1) channel, used on two subs. I know it can be done, thats now what I'm saying. What I am saying, If JL say's it's ok, then how would they wire it. In parallel, or in series. If you shoot them an email, or even call their tech line, I'm sure they would help.
Old Aug 29, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
damn great advice there!!!^
Old Aug 30, 2006
jayjdlc's Avatar
how do i check the vehicle factory ground wire? where is a better place to ground it?
Old Aug 30, 2006
FreedomEagle's Avatar
FreedomEagle has a spectacular aura aboutFreedomEagle has a spectacular aura aboutFreedomEagle has a spectacular aura about
ok listen to this advice cause this has happen to me. i have 2 big *** subs and out of no where the same thing started to happen to me but they would just go out and come back on..
what happen was is that i have so much bass that the bass rattled out the fuse to my amp just enough that its connected but when it hit hard it would push it loose a little check it and let me know
Old Aug 30, 2006
05civicFun's Avatar
05civicFun is an unknown quantity at this point
the gain could be set to the point of where its overheating after an hour or so, if its taking that long, it shouldnt be the charging system, try turning the gain down a little bit
Old Aug 30, 2006
02SILVEREX's Avatar
I still feel you need to refer to the specs from JL. http://mobile.jlaudio.com/pdfs/7591.pdf Their tech line is very helpfull.
coumadin01
Electronics
25
Jul 25, 2019 04:19 PM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
