Probably Blew My Amp.
Old Jul 28, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
Im running a Kicker ZR series amp to 2 Infinity Reference Series speakers up front. I went to turn up my tunes when I was on my way home from work, and the amp sounded like it just turned on and off repeatedly and then went off. I got home and realized that a fuse had blown somehow, so I replaced it. I hooked up the amp and tried to get it going again. This time, everytime it turned on, it would go right into protective mode, and then pause for 5 seconds outside protective mode and go back into it. Anyone know what might be causing this? Should I just invest in a new amp or try something else?
Old Jul 28, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
Check your ground wire. Make sure its grounding properly. Sand the area you are ground to.
Old Jul 28, 2006
thefever's Avatar
I need a drop
Grounds perfect, checked, double checked and triple checked.
Old Jul 28, 2006
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
try disconnecting your speakers from the amp, something might of happened and they are shorting out, causeing the amp to go into protect mode.
Old Jul 28, 2006
4Saris's Avatar
4Saris is an unknown quantity at this point
The ground would have been my guess. Try disconnecting one thing at a time to isolate the problem. First each speaker, then each RCA. Troubleshooting with amp issues takes some time.
Old Jul 28, 2006
gangster91688's Avatar
gangster91688 will become famous soon enoughgangster91688 will become famous soon enough
sounds like u burnt your amp.... u just need a new amp.... my friend had the same problem as you n he tried everything but nothing work so he just got a new amp n things went back to normal.
Old Jul 29, 2006
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
Id check all the connections, sounds like some wires may be touching where they shouldnt. If anything, I would probably take it to an audio shop to tell me that it is blown, but if you werent happy with it before, then maybe this was a good coincidence. Tell me how it works out.
Old Jul 31, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
if the amp is going into protectant mode that doesn't mean its burnt out, it means its trying to prevent itself from burning out.
This happened to me a while back. Check the connections on the speakers, and make sure that no part of the speaker wire is touching the metal on the doors. Unbolt the speakers and have someone hold them, then try turning on the car and see if its working.
Old Aug 1, 2006
jay47's Avatar
jay47 is an unknown quantity at this point
Like they said, try adjusting one thing at a time and maybe you can fix the problem.
Old Aug 1, 2006
thefever's Avatar
I need a drop
Alright, got the amp working. Checked the wires in my door, and sure enough, they were touching. That was alot of help, I would have never even thought to check that. Thanks alot ashtonp. Plus 1 rep.
Old Aug 1, 2006
ashtonp's Avatar
any time
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
charmon4815
General
Sep 22, 2015 08:00 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
Gsxtacy
Sep 12, 2015 01:09 AM
JJ291
Sep 2, 2015 11:49 PM
