I just installed(expensive)new 6.5 and 6x9's
Old Mar 5, 2002
HondaLuver's Avatar
Its a celebration bitches!
I recently got a place to install speakers in the back and front. It cost my 100 bucks for installation, i watched the guy do it also. I bought some pioneer 200 watt 6.5's for the front, and pioneer 300 watt 6x9's in the back. I though they would fit so i went to downtown LA and bought the 6x9's for 68$ and the 6.5's for 50 bucks. That is real cheap for some good speakers.
So the guy installed the 6.5s in the front. He put them in, he needed spacers. He also had to cut some metal because the 6.5 was too big. Then he installed the 6x9's in the back, he tried to put it in but it was really hard, he pulled back the sides and took off the back deck. To my supprise, the speaker depth was tooooo deep. So i had to un clip the trunk springs and bend them alot. They are rubbing agaist the speaker magnets right now.
it took them about 1 hour in a half. The guy that did it was dead tired from all that work. I think honda has a good car, but the installation of my speakers is really stupid. I am thinking of getting a fosgate 600.4 for my speakers and changing the stock tweeters. Right now i have 12 tweeters total. When i turn the stock head unit all the way up it has good highs and tweets, even when the bass hits. I am afraid that my stock head unit will blow soon since it sounds good all the way up.
If any one has any ideas so i can close the trunk better with out the stock springs, let me know you suggestions.
Old Mar 5, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
i kinda got that same prob, but just put some soft tape around the springs till i get something better. I was thinking about getting the vertical trunk lift kit, that'd solve the spring problem for sure.
Old Mar 6, 2002
Starkfu's Avatar
Starkfu is an unknown quantity at this point
get rid of the pioneers and put in some mb quarts, they fit perfect and sound a lot better.
or you could make your own trunk rod, or mod one from another vehicle.
Old Mar 7, 2002
Squirt's Avatar
Squirt is an unknown quantity at this point
hey, do the mb quarts need cutting and/or drilling for the front components? i tried to put them in, but they didn't seem to fit good (maybe cuz i'm new at this stuff), so i'm trying to get my friend to help me. but some insight would help a lot.
thanks
Old Mar 7, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Go with CD technologies www.cdtaudio.com they make stuff that blows MB quart away...
Old Mar 7, 2002
avenger's Avatar
avenger is an unknown quantity at this point
polk dx9's in the back w/o modification
Old Mar 7, 2002
IDQcivic's Avatar
Don't enough mess with rear fill... rear fill sucks, it messed up the whole sound stage, you want the sound to be coming from the front to it gives the illusion of you bass coming from there as well, 6x9's distort and sound sloppy. Get yourself a good componenet set up front, and feed each side a good amount of clean power, and it should sound great...
Old Mar 7, 2002
HondaLuver's Avatar
The speakers sound sooo nice, i get such good sound when i turn my stock head unit all the way up, i get a little bass but over all i get the clearest sound you can get, i just need some bass, so i will first get a better alternater since i have AEM pulleys, so my car can hadel it. All together i have 12 tweeters, including my stock ones.
Old Mar 8, 2002
IDQcivic's Avatar
If you added new 6x9's and 6.5's how exactly do you have 12 tweeters, that is nuts.... and if you took your stock door speakers out, your stock tweeters probably arent even working... clearest sound you can get, from pioneer and stock head unit??? I don't think you've heard good sound.... try getting some amps and a descent head unit, and some descent speakers too.
Old Mar 8, 2002
01IncaPearl's Avatar
01IncaPearl is an unknown quantity at this point
<< The speakers sound sooo nice, i get such good sound when i turn my stock head unit all the way up, i get a little bass but over all i get the clearest sound you can get, i just need some bass, so i will first get a better alternater since i have AEM pulleys, so my car can hadel it. All together i have 12 tweeters, including my stock ones. >>
you should go and listen to a setup that is powered correctly and you will see a big difference in the way it sounds compared to yours. And dont you think thats a little to much tweet for just a factory stereo, or for any stereo setup.
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
ZILLA
Jul 13, 2015 04:52 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
