K24a4 swap??
Old May 21, 2006
Bojangles80's Avatar
Bojangles80 is an unknown quantity at this point
K24a4 swap??
I've been doing my research on a k24 swap and everyone is always talking about the CRV and TSX k24s but I don't read much about the Element k24. From what I understand the Element K24 is the same as the accord but i was wondering if it's an easy swap to put in the element k24 into my civic. Any details would be useful or any concerns... thanks
Old May 22, 2006
modoman's Avatar
it looks like a very tall engine with the head and oil pan, but i dunno.
Old May 22, 2006
Nick's Avatar
Formerly 2blu
it should be the same.
Old May 22, 2006
acidbaby's Avatar
The Beez Kneez
no swap on our car is easy:/
ask HAWK he has done alot of research on this motor..
Old May 22, 2006
imsonastie's Avatar
imsonastie is an unknown quantity at this point
looks the same to me, the tranny, i/e manifolds might be different. id think its THE EXACT SAME as the crv.
Old May 23, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
all k24s EXTERNALLY are the same.. they all swap in the same as any k24 as how you would swap a k20.....
HOWEVER.. here are the differences in actual performances
K24A1 (PPA), CRV (LRD)
160hp @ 6000rpm / 162lb-ft @ 3600rpm
Redline: 6500rpm
Compression: 9.6:1
K24A2 (RBB),TSX (CL)
200hp @ 6800rpm / 166lb-ft @ 4500rpm
7100rpm
10.5:1
*K24A3 (RAA), Accord (03+ CM, 5th Gen V6 and Wagon CE)
160hp @ 5500rpm / 161lb-ft @ 4500rpm
6500rpm
9.7:1
*K24A4 (PZD), Element (YH)
6500rpm
9.7:1
The only reason you might read about people using a certain block over another is the fact due to clearance issues with swapping a k20a2 head on a k24 block to do what we call a FRANKENSTEIN... this by all means gives you the power of the K20 with the TORQUE of the K24... here is what i mean.. the following below is the types of k24 blocks and also if they will accept a k20 head
K24A1 (crv) - yes
K24A2 (tsx) - yes
K24A3 (element) - no, valve clearance issues
K24A4 (accord) - no, valve clearance issues
as you can see that the element and the accord k24 blocks have clearance issues when running a k20 head.. by all means if you are going to do a frankenstein then you need to either use a TSX or CRV block... but if you want a straight k24 you can use any of the k24 blocks...
With a TSX block, k20a2 head, h.c. valves, and kpro, you will have around 207hp 175 TQ on a Mustang Dyno, with k20a2 block, k20a2 head, h.c. valves and k pro, you will have 210hp 155pound. The power from the k20a2 block will be between 6k and 8.5k. With the TSX block, the power will come earlier between 4.5k and 7.5k and sometime 8k.
Old May 23, 2006
HondaLuver's Avatar
Its a celebration bitches!
hummm
Old May 23, 2006
suthrninca's Avatar
suthrninca is an unknown quantity at this point
Does this mean that the exhaust mani's or headers are interchangable?
Old May 23, 2006
modoman's Avatar
well poo, because there are some cheap accord engines on ebay but i would only want a k24 for a the head swap
Old May 23, 2006
you can use the other 2 k24 motors that would have clearance issuse if you swapped head BUT... there is a big but... you have to either use i think it was the TSX rods and pistons ... OR... get aftermarket rods and pistons...
Old May 23, 2006
modoman's Avatar
more $... cancels it out
Old May 23, 2006
if you want a straight k24 swap hassle free no more money to spend then you can use ANY of the k24 engines... but if you sometime down the line decide to put on a k20a2 head then you are screwed with the accord and element blocks
Old May 29, 2006
suthrninca's Avatar
How far off is the header/exhaust alignment after the k swap?
Old May 29, 2006
HondaLuver's Avatar
you need a new exhaust pipe when you get a swap. you can use any rsx header. i suggest only getting type S parts.
Old May 29, 2006
suthrninca's Avatar
So just drive to the muffler shop with open header and have them mate header to exhaust. Won't they have to cut a good bit off the front of the exhaust where it goes under the d17 to the d17 header? I already have a 2.5 inch thermal RandD exhaust. Will this be big enough for a k24a1/k20a2?
Old Jun 1, 2006
acidbaby's Avatar
The Beez Kneez
LOL
i meant HondaLuver
Old Jun 7, 2006
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
does anybody know of a good place to buy the k20heads? Every junkyard and salvage place around here will not break up the motors since they are so new. I just got a price quote of 1400 for a k24a2.
Old Jun 7, 2006
HondaLuver's Avatar
k20a.org, clubrsx.com
d17s are not interchangable with k. nothing is. you need a new header and b-pipe
1400 is good for a k24a2, but you still need a k20 manual tranny, subframe, k20 TB and intake mani. you will also need kpro and all other swap things
Old Jun 8, 2006
suthrninca's Avatar
I just picked up a k20a2 head on K20a.org. I'm getting the complete head (04, 32K) in perfect condition with IM and TB (all sensors), injectors, fuel rail, head studs, and throttle cable all for $925 shipped. Yeah, what HondaLuver said. Just keep watching the classified forums at clubrsx.com and k20a.org, you'll find one. That's a sweet price on the tsx engine.
Old Jun 8, 2006
You VTEC...I-VTEC
is there only one head on a k20? Cause i know on my porsche engine it has 2.
Old Jun 8, 2006
suthrninca's Avatar
Yeah, inline 4's have one head. Inline=one head, V or Flat=2 heads.
Old Jun 8, 2006
You VTEC...I-VTEC
that makes sense. good news too, now i dont have to spend as much money
Old Jan 13, 2009
chasesk20eg's Avatar
chasesk20eg is an unknown quantity at this point
Re: K24a4 swap??
What parts do I need to put a type s 6 speed tranny to a k24a4? Does annyone know?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
