Fuel economy with Turbo D17
Old May 18, 2006
hondaudio's Avatar
hondaudio is an unknown quantity at this point
Hi
If a when install turbo kit. do deincrease (-) a lot your fuel economy. Or is not bad. It sure i understant that if accelerate a lot ist normal. but daily driver it'is ok (not always on the boost). Please help and give some anwser.
Thank for all
Alexandre
Old May 18, 2006
RussEXT's Avatar
RussEXT is an unknown quantity at this point
its not bad at all I get 30-32 mpg highway
in town I dont know. its ruffly the same if you dont boost
Old May 18, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
its hard to stay out of boost when you have it on tap lol.. if you granny drive it most and keep it in vac then you'll get close to your stock mpg. tuning plays a big role too of course, you dont want to be pig rich all over wasting fuel. At the same time, you dont want to be too lean , then you'll break something.
Old May 19, 2006
blouisgod's Avatar
Life Begins > 6800rpms
just dont mash the pedal. use the vac side of your boost gauge to keep tabs on pressure; sometimes youll have to climb rpms to save load on the engine. seems
backwards, but it works. I hit close to 43 mpg on the highways the other day.
Old May 19, 2006
skipbarber's Avatar
it's pretty easy: stay out of boost, and youll save money on gas. Some of us dont have the will power to do that though lol..
Old May 19, 2006
eye_see_you's Avatar
let the devil out
stay out of boost and tune right your good to go
Old May 19, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
my gas milage didn't drop that much when I had a turbo.
I went from about 32 mpg combined cty/hwy n/a to 30 mpg city/hwy combined turbo.
with my swap, I'm getting 26 mpg combined.
Old May 19, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
I'm doing better with it.
More power = less high reving, lower RPM upshifts;
higher gears = lower RPMs = more MPG
Haven't filled it enough to get a good handle on it, but its looking like about a 4 MPG gain.
Old May 23, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
yeah it look like it does not mess with it
Old May 25, 2006
ShoelessEX's Avatar
The wheel is turning...but the hamster is dead
ShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to all
I think I get better....casue full throttle stock = about half throttle turbo...there for less gas...but then again I never thought I would see the day a civic took $45 to fill up the tank! damn 93
also make sure you get it tuned real good...I had mine tuned on a mustang dyno so I could cruise the car @70mph to lean it out for highway driving.
Old May 25, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
i have a question, if ur under boost or in vac, does that means that it really just like stock no HP is added right? also if ur under boost will the BOV still go off? sry i dont know to much about it..
Old May 26, 2006
skipbarber's Avatar
no boost = like stock, underboost the bov will open when you let off the throttle. the BOV's job is to save the turbo from compressor surge or forcing your throttle plate into your intake manifold, lol.
Old May 26, 2006
dezod's Avatar
7thgen Power Maker
Not 100% true. That is what a ported shroud is for.
To the original poster-If your concerned bout fuel economy, do not do turbo. Simple as that. Performance and fuel economy are not even supposed to be used in the same sentence except to disclose you have an 8 sec car with 4 miles/gallon fuel economy.
Old May 27, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
That is not 100% true.^
You can get excellent fuel economy with the right tuning, even with a supra.
Old May 28, 2006
hondaudio's Avatar
I Thing that a have all i need to know about turbocharger. mY civic have 45000km it is to late to put turbo on it a suppose that is ok. Today a try a volkswagen jetta with 1.8t motor and is very do. I want turbo my d17. Can i have approximately the same hp (power with a d17 turbo because a don't try it)?
Thank for all
Alex
Old May 28, 2006
ncirom2003's Avatar
people will call BS, in fact at first i did on myself hhahaha
but before my turbo, 100% stock... i was averaging 27 mpg city (boston driving and stuff haha, real city not rural roads) and after the turbo and all that, the next tank of gas i drove around beating the bag out of my car, always mashin teh gas and once in a while driving out of boost. i got 26.5 mpg........eya i know its nuts but hey w/e im happy lol
Old May 29, 2006
dezod's Avatar
7thgen Power Maker
When I had my turbo D17, I guzzled gas when I was driving hard. I was getting 20mpg or less sometimes.
Old May 29, 2006
if i stay out of boost, then i got just about normal, if not better milage..
i did abuse the **** out of it once and i burned a quarter tank in 50 miles.. with a/c on, no less.. lol
GritzNGravy
Aug 19, 2015 03:03 AM
justcruzin125
Aug 11, 2015 09:09 PM
Civicircus
Aug 6, 2015 11:58 PM
alxz310
Jul 30, 2015 12:18 PM
Green02civic
Jul 27, 2015 10:48 PM
