Fuel economy with Turbo D17
Hi
If a when install turbo kit. do deincrease (-) a lot your fuel economy. Or is not bad. It sure i understant that if accelerate a lot ist normal. but daily driver it'is ok (not always on the boost). Please help and give some anwser.
Thank for all
Alexandre
Thank for all
Alexandre
its hard to stay out of boost when you have it on tap lol.. if you granny drive it most and keep it in vac then you'll get close to your stock mpg. tuning plays a big role too of course, you dont want to be pig rich all over wasting fuel. At the same time, you dont want to be too lean , then you'll break something.
just dont mash the pedal. use the vac side of your boost gauge to keep tabs on pressure; sometimes youll have to climb rpms to save load on the engine. seems
backwards, but it works. I hit close to 43 mpg on the highways the other day.
it's pretty easy: stay out of boost, and youll save money on gas. Some of us dont have the will power to do that though lol..
my gas milage didn't drop that much when I had a turbo.
I went from about 32 mpg combined cty/hwy n/a to 30 mpg city/hwy combined turbo.
with my swap, I'm getting 26 mpg combined.
I'm doing better with it.
More power = less high reving, lower RPM upshifts;
higher gears = lower RPMs = more MPG
Haven't filled it enough to get a good handle on it, but its looking like about a 4 MPG gain.
The wheel is turning...but the hamster is dead
I think I get better....casue full throttle stock = about half throttle turbo...there for less gas...but then again I never thought I would see the day a civic took $45 to fill up the tank! damn 93
also make sure you get it tuned real good...I had mine tuned on a mustang dyno so I could cruise the car @70mph to lean it out for highway driving.
i have a question, if ur under boost or in vac, does that means that it really just like stock no HP is added right? also if ur under boost will the BOV still go off? sry i dont know to much about it..
no boost = like stock, underboost the bov will open when you let off the throttle. the BOV's job is to save the turbo from compressor surge or forcing your throttle plate into your intake manifold, lol.
7thgen Power Maker
To the original poster-If your concerned bout fuel economy, do not do turbo. Simple as that. Performance and fuel economy are not even supposed to be used in the same sentence except to disclose you have an 8 sec car with 4 miles/gallon fuel economy.
I Thing that a have all i need to know about turbocharger. mY civic have 45000km it is to late to put turbo on it a suppose that is ok. Today a try a volkswagen jetta with 1.8t motor and is very do. I want turbo my d17. Can i have approximately the same hp (power with a d17 turbo because a don't try it)?
Thank for all
Alex
Thank for all
Alex
people will call BS, in fact at first i did on myself hhahaha
but before my turbo, 100% stock... i was averaging 27 mpg city (boston driving and stuff haha, real city not rural roads) and after the turbo and all that, the next tank of gas i drove around beating the bag out of my car, always mashin teh gas and once in a while driving out of boost. i got 26.5 mpg........eya i know its nuts but hey w/e im happy lol
if i stay out of boost, then i got just about normal, if not better milage..
i did abuse the **** out of it once and i burned a quarter tank in 50 miles.. with a/c on, no less.. lol
GritzNGravy
Aug 19, 2015 03:03 AM
Civicircus
Aug 6, 2015 11:58 PM
alxz310
Jul 30, 2015 12:18 PM
Green02civic
Jul 27, 2015 10:48 PM
