Need help with HOOD problem
Old May 18, 2006
ZapThyCat's Avatar
ZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to behold
The hood latch on my car failed on the freeway at 70 mph. So I need a new hood (and windshield, but that's a different story).
I'm looking on getting a used CF hood, with hood pins. What all do I need to be able to keep the hood down without using the hood latch (which I am going to get fixed, but not yet)? I need to get this car back up and running.
Do I need anything to install the hood pins? Will the hood pins be enough to keep the hood down?
This is the cheapest and quickest fix right now, for the hood. I want to get this car up and running again. Please give me some tips... thanks!
Old May 18, 2006
jdmfan13's Avatar
jdmfan13 is an unknown quantity at this point
Hark... the info is here:
http://www.7thgencivic.com/forums/sh...d.php?t=155293
Check it out. Now what's this about points and a reward???
You may also borrow my dremel & drill, if you come down and get them... lol!
Old May 18, 2006
ZapThyCat's Avatar
400 mile journey? no biggie!
Old May 18, 2006
jdmfan13's Avatar
I'll even help install it!
Old May 18, 2006
ZapThyCat's Avatar
I can't rep you because I already did. PUNK MONKEY!
Old May 19, 2006
blouisgod's Avatar
Life Begins > 6800rpms
If you can get the hood, i can guide you through a hood pin install. youll have to drill the hood with a drill and youll need a dremel also. its a bitch, but if you are careful, it will come out great.
Old May 19, 2006
ZapThyCat's Avatar
The hood is already drilled and the hood pins installed, I'm wondering what it takes to get the hood pins installed on the car....
Old May 19, 2006
blouisgod's Avatar
depends on where they are. on the stock radiator support, there are two rubber stoppers where I mounted the shafts so no drilling. hopefully, they are there.
Old May 19, 2006
ZapThyCat's Avatar
Fixed! Thanks guys...
roverben
Jan 21, 2019 05:16 PM
usajags84
15
Aug 19, 2015 03:12 AM
JAMorganIII
23
Jul 4, 2015 11:52 AM
crowtoo
May 11, 2015 06:50 PM
vtexcivic
Dec 17, 2001 02:08 PM
