disconnecting battery and its effects ??
Old Apr 26, 2006
sid21177's Avatar
sid21177 is an unknown quantity at this point
Hi,
I need to go out of the country for 3 months.
I have a 2005 Civic which will remain parked/unused for the above period.
I would be very grateful if someone could provide insight to the following questions.
1) The honda manual recommends disconnecting the battery, should I do it ??
2) I know disconnecting will reset the radio, will it also reset the odometer ??
3) Is there anything else that gets affected due to battery disconnect ?? - lol
Thanks,
Sid
Old Apr 26, 2006
Graphicdude's Avatar
Creative Mind Extraodinare
Graphicdude will become famous soon enoughGraphicdude will become famous soon enough
If the manual says so, then its fine.
The OD? Your kidding right?
The only other thing that willbe affected when disconnecting the battery will be NO POWER TO YOUR CAR
Old Apr 26, 2006
sid21177's Avatar
This is what my dealer technician told me - LOL
I found this strange, so I was trying to confirm
Old Apr 26, 2006
diskreet's Avatar
You'll lose any settings on your radio, and the code will be required if you have the OEM stereo. Otherwise, just re set the clock and you are all set
Old Apr 26, 2006
Sinisterdexter's Avatar
I Pinch.
Sinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of light
Don't forget to change the headlight fluid and to reset the elbow grease pumps before you leave.
Old Apr 26, 2006
AlienX's Avatar
AlienX will become famous soon enough
my headlight fluid has been low since i blacked out, how do i refill
but on a side note, there are some other things you should do when storing the car. Id search for you, but im one lazy ****...
SimpleUser
Apr 24, 2021 02:54 AM
Uan
Aug 23, 2015 03:03 AM
mcollins
Electrical
Jul 27, 2015 10:59 PM
cukaracha
Jul 17, 2015 05:48 PM
magog45
Jul 9, 2015 06:23 PM
