disconnecting battery and its effects ??
Hi,
I need to go out of the country for 3 months.
I have a 2005 Civic which will remain parked/unused for the above period.
I would be very grateful if someone could provide insight to the following questions.
1) The honda manual recommends disconnecting the battery, should I do it ??
2) I know disconnecting will reset the radio, will it also reset the odometer ??
3) Is there anything else that gets affected due to battery disconnect ?? - lol
Thanks,
Sid
Thanks,
Sid
Creative Mind Extraodinare
If the manual says so, then its fine.
The OD? Your kidding right?
The only other thing that willbe affected when disconnecting the battery will be NO POWER TO YOUR CAR
You'll lose any settings on your radio, and the code will be required if you have the OEM stereo. Otherwise, just re set the clock and you are all set
my headlight fluid has been low since i blacked out, how do i refill
but on a side note, there are some other things you should do when storing the car. Id search for you, but im one lazy ****...
