30,000 mile service
Old Apr 19, 2006
dallasaudio's Avatar
dallasaudio is an unknown quantity at this point
Question 30,000 mile service
I recently rolled over 30,000 and I need to know what maintence I need to get done. I change my oil every 3,500 and rotate every 7,000. I just got finished changing my engine air filter. Anything else I'm missing? I plan to buy spark plugs and have a shop put them in(I don't have the tools and had a bad experience in my old car) and was wondering what a good pirce is to have this done.
Old Apr 20, 2006
Jrfish007's Avatar
http://www.7thgencivic.com/forums/sh...d.php?t=251419
and
http://www.7thgencivic.com/forums/sh...d.php?t=255212
Your manual says your plugs are good for 100,000 miles, I would bother changing them before say 50,000 and they are platinum
Old Apr 24, 2006
mikem317's Avatar
mikem317 should not be trusted
A dealership near me wants $415 for the service through.
I have 24,200 on the clock right now. I'm prob. going to do it myself. This maintenance stuff is pretty easy. It prob. totals less than $100 retail in parts.
Old Jul 25, 2006
SinaloaCivic's Avatar
Ill punch you in the face before you visit Myspace
SinaloaCivic is an unknown quantity at this point
i have 22,500 miles and when i hit 30K im doing that maintenance, just because i cant do anything..........and i cant have my car **** up...but then im sure it wont.....eeh
Old Jul 26, 2006
streetglower's Avatar
for the 2 of you who want maintenence at 24,000 and 30,000 miles, it is not necessary. there isnt much that needs to be done. Spark plugs are good for 75,000-100,000 miles, coolant is good up till 100,000 miles, you have already changed your oil, and air filter. only thing that is done at these intervals in checking everything, brakes, suspension, etc... and that stuff the dealer just looks over, if even at all and charges a **** load.
Most of that you can check yourself.
Now if you want and may do is change the tranny fluid if you have an automatic. a drain and refill is fine. very easy to do.
Old Jul 26, 2006
trans fluid, brake fluid (every 3 years), coolant
Old Jul 28, 2006
mikem317's Avatar
Weird. I think I have to change the brake fluid on my CBR every year, or something like that. Supersports are like that, I guess.
Old Jul 30, 2006
fulltimeride's Avatar
fulltimeride is an unknown quantity at this point
i rolled over 34000 and i'm planning on plugs, fuel filter, cabin filter(smells like cigs, stupid me) synthetis trans fliud and syn power steering fluid. the synthetic will help move thing more smoothly and get better mpg and same with the plugs and fuel filter. i was gettin 450-500 a tank and now get at most 380, gas price suck so doin this stuff to ur car is good no matter how u look at it.
Old Jul 30, 2006
damn you are just waisting your money on all of that.
I would change the plugs maybe at 50-75,000 miles, the fuel filter is in the fuel tank and its a lifetime filter and expensive (around $50), cabin filter is fine, if you have an auto I would use honda ATF, nothing else, and you dont even need to worry about the PS fluid. Your at an early mileage. Most I would do is an oil change, air filter change, bleed the brakes, and change the tranny fluid.
Old Aug 21, 2006
patliean1's Avatar
patliean1 is an unknown quantity at this point
Thanks for the info!
Old Aug 30, 2006
runner1738's Avatar
i got a coupon for 319 but still i dont have that much right now, so im doing it in steps, i did an oil change tire rotation, changed the air filter, cabin filters, i need to get the atf fluid change and im due for an oil cahnge so im having the oil filter changed as well, but all that other stuff was inspection stuff, i have new brakes which should be coming up soon, so im not worried, but i am out of warrenty now
Xuhme
21
Aug 7, 2023 03:40 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
beachglass
May 22, 2015 09:59 PM
Fastfebur
Apr 26, 2015 11:57 PM
